Will die at random
Old Mar 9, 2013 | 09:39 AM
logger250's Avatar
logger250
Will die at random
1997 f450 2wd 7.3l While driving when the truck it up to temp (after about .5 hrs driving) It will turn off like a light switch engine will just dye no sputtering nothing.
Use to be every few days it would do it 1 time then I could start back up while still driving. Now it has progressivly gotten worse after about an hour of driving it will turn off you will have to let it sit for a couple hours than it is drivable agian. Sugestions?
Old Mar 9, 2013 | 09:44 AM
ReBilld's Avatar
ReBilld
It's the CPS (Cam Position Sensor). Get one from Ford or IH. The parts store ones don't last. It's very easy to change, takes about five minutes. It's located on the front of the engine down by the crankshaft. It has a metal bracket with one 10mm bolt that holds it in.
Old Mar 9, 2013 | 05:18 PM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
PREMIUM SPONSOR
I agree.
It could definitely be the CPS, and as stated above, do not use aftermarket.
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
terrylamar
40
Jan 21, 2014 08:46 AM
jsrdaily
Jun 3, 2007 09:30 AM
catman340
Feb 22, 2007 03:06 PM
BJB6521
Apr 5, 2006 02:49 PM
loadera10
Feb 1, 2006 04:29 AM
