Intake woes!!!
Old Mar 8, 2013 | 11:18 PM
jmcnair40's Avatar
jmcnair40
Intake woes!!!
Recently, I rebuilt my 390 fe. All went well until fire it up time came. Fired right up, but it smoked like crazy. I went through it again. Long story short, I'm 99% sure it's because after I had the machine work done, I did'nt take in to account the difference of angles between the new surfaces and the intake manifold. I also did'nt remove the splash pan in the valley of the block. So....am I on track here? I'm using an Edelbrock aluminum intake...Will I have to get a different one? Appreciate the input...
Old Mar 9, 2013 | 12:30 AM
brian1080's Avatar
brian1080
Does it keep smoking? Maybe you just had some oil in the cylinders or intake that needed to burn off after the rebuild. I wouldn't think the small amount taken off would make the intake gaskets fit any different, they should be thick enough to take up that space.
Old Mar 9, 2013 | 12:47 AM
jmcnair40's Avatar
jmcnair40
no...way past break in ...still smoking..compression great...rings perfect...still smoking...must be intake..oil in ALL EIGHT.
Old Mar 9, 2013 | 12:51 AM
brian1080's Avatar
brian1080
you say you didn't remove the splash pan? So you reused the gaskets that were in it before the rebuild?
Did you get new headgaskets after the machine work? are they the right ones?
Old Mar 9, 2013 | 01:21 AM
mikeo0o0o0's Avatar
mikeo0o0o0
I had a similar problem years ago on a 428 I rebuilt. It had the wrong intake manifold gaskets. The gasket ports were short. They sealed around the top and sides of the port but along the bottom of the port there was a small gap between the gasket and port, this allowed it to suck oil in from the valley area.
Old Mar 9, 2013 | 11:07 AM
montana_highboy's Avatar
montana_highboy
Are all the plugs oily or just a few?
Use the drain tins under the rocker stands?
Have a functioning PCV system?
Any chance it is over filled with oil?
Install restrictors in the heads?
Retorqued the intake bolts?
What intake gaskets did you use?
jakeharp
Oct 13, 2016 06:24 PM
Boomco
Apr 20, 2015 08:59 PM
mrfox0246
Mar 28, 2010 01:00 PM
boggerted
Aug 6, 2008 10:53 PM
THEGAME304
Oct 20, 2004 04:32 AM
