I HATE TORX!!!!!
Old Mar 8, 2013 | 05:35 PM
JayzDaddy's Avatar
JayzDaddy
Cool I HATE TORX!!!!!
Retrofitting a tailgate from a 96 to my 86. Didnt know til i tried to fit it the 2 mounts on a newer one are smaller. T47 torx driver fit the newer model and they came out fairly easy with some pb blaster. The old ones take a T45 torx driver. My luck they were pretty much welded in with rust. Broke 2 driver bits even after a propane torch and pb blaster. Took 3 hours, 2drill bits, and hammer and chisel to get the old mounts off.
But its done. I got a tailgate for my truck. Its not a factory style for my model but i dont care. I just wanted a functional tailgate that wasnt gonna fold in half when my big butt sits on it like the $100 dollar jobs from lmc. I gotta sand and primer it tomorrow after i install my headlights and tail light lenses.
Ill thow up some pics when i get done.
Old Mar 8, 2013 | 07:17 PM
9wire's Avatar
9wire
I had the same problem with my JY outside mirror, the mirror I got was on the wrong bracket, the torx bolt was a bear. Luckily a buddy had a 1/2" drive torx bit set, we got it off.
Old Mar 8, 2013 | 08:03 PM
JayzDaddy's Avatar
JayzDaddy
I guess on a good note when i went to pull the crappy plastic bedliner cover off the tailgate those torx came out easy as mexican food the day after.
Old Mar 9, 2013 | 12:58 AM
TheKirbyMan's Avatar
TheKirbyMan
That is an uncomfortably true comparison right there.
Old Mar 9, 2013 | 09:13 AM
JayzDaddy's Avatar
JayzDaddy
Gets the point across with no wiggle room for misinformation.
Old Mar 9, 2013 | 09:20 AM
GLR's Avatar
GLR
A little late now but, When trying to take the brackets and mounts off, I found that taking the tail lights out and spraying penetrant from the back helps to loosen the bolts.
Old Mar 9, 2013 | 12:00 PM
Mediarocker's Avatar
Mediarocker
^^ That's some good information there. The real problem isn't so much the friction on the threads, it's the rust and crud that has built up on the exposed part of the bolt.
And Torx are great for keeping people from stealing your stuff!... Just a royal pain when it comes down to doing maintenance. My whole Jeep was made out of Torx Screws... even the TPS on the throttlebody was Torx'd on (which I had to cut off!).
Old Mar 9, 2013 | 12:39 PM
JayzDaddy's Avatar
JayzDaddy
Yep. I spotted that. I was changing rear lenses and didnt want to risk hitting the old ones with the drill or chisel.
I used pb blaster and a propane torch and even tried a terminal cleaner on the threads. They just wouldnt budge.
Bjw406sa
Sep 18, 2018 11:25 PM
DGB3
Jun 15, 2015 09:36 PM
5.4f250sd
Jul 27, 2010 06:06 PM
FordTruckGuySTX
Feb 21, 2006 09:19 PM
fordtruckguy2223
General Automotive Discussion
Feb 21, 2005 11:46 AM
