Sponsored by: Real Truck
adjustable boost fooler kit
Old Mar 8, 2013 | 01:39 PM
Yingling256's Avatar
Yingling256
i have a 2003 ford f250 7.3l super duty with TS proformance chip, exhaust, cold air intake, EGT Boost and Tranny Temp gauges. the waste gate is blocked off and im looking to get an adjustable boost fooler, is this a good idea or no??
Old Mar 8, 2013 | 08:26 PM
F350-6's Avatar
F350-6
How much boost can you hit now? If you reach the point that the computer defuels the truck, then yes you should put a boost fooler on the MAP line.
Old Mar 9, 2013 | 07:57 AM
Yingling256
On the 120 hp race tune I'm about 32psi at 100mph. I was thinking that is pretty low for what I have??
Old Mar 9, 2013 | 09:08 PM
F350-6's Avatar
F350-6
The TS is a relatively mild chip, so 32 psi is plenty of boost if you've got a stock turbo and stock sticks. If you're seeing that much boost, it sounds like your tuning is taking care of the defueling thing and a boost fooler may not be needed.
Of course the stock turbo tends to get a much shorter life when you take it beyond 25 psi or so, so save your money for a better turbo.
Old Mar 11, 2013 | 01:19 PM
Yingling256
OK what size of Turbo would be good?? The only thing I'm worried about is the 02-03 have the weaker connecting rods and I don't want to put to much hp to them and snap a rod
Old Mar 11, 2013 | 06:53 PM
F350-6's Avatar
F350-6
32 psi of boost is not going to harm your connecting rods. Good tuning can take you well North of 400 hp on powdered rods and you'll still be fine. But 32 psi of boost is going to shorten the life of your stock turbo, so start saving your pennies for a 38R or some other upgrade.
Edit: And a boost fooler won't save your PMR's either. It just keeps the truck from de-fueling or setting a CEL, which it sounds like yours isn't doing anyway.
imjwm
15
Feb 6, 2016 07:37 PM
derek0525
13
Jan 19, 2016 03:57 PM
crazer42
May 8, 2010 12:42 PM
StampedePSD
44
Jan 11, 2009 12:21 AM
MikeSDK
Jul 13, 2007 05:30 PM
