Ok guys, my 63 has a 302 in it. This conversion was done before i got the truck so the crossmember is from an unknown source and so are the motor mounts. The mounts have no numbers on them for ID and are in need of replacing. They appear to be either from a bronco or early mustang based on the shape. They have 2 outer holes for bolts to go into the block and then either have a central stud or bolt that passes through the bottom of the mount to secure it to the cross member.
Heres some pics. Better ones to come tomorrow:
Heres a link to the bronco mounts that seem similar...
You might have to take them with you to a decent parts store. Perhaps they can match them for you.
I had to do this with the tranny mount for my f100; when they looked up the part, the one they gave me was for a manual which seemed logical since I have a manual but it didnt fit. It turned out that some how I have what the parts system refers to as an automatic mount. Wouldnt have figured this out without taking it in to compare or making a dozen trips back n forth until I got it.
