Motor mount design help
Old Jul 6, 2012 | 12:13 AM
Holehawgg's Avatar
Holehawgg
I have the jag front end mounted except to install clips on the torsion bar and box the frame. The 289 is ready to pick up from the rebuilders right away and bolt to the tranny for fit up of the motor mounts and tranny cross member. Could some of you post pics of your motor mounts? I would like to use the original style of mount if possible. If not I have the jag mounts and could do like Jeff (Jeff and Nichole) has done but would really like to see some other options as well. Hope some of you can help.
Old Jul 6, 2012 | 12:30 AM
tractormanbill's Avatar
tractormanbill
tractorman
motor mounts
These are easy and only use the original block mount not the motor mount. They can be welded or bolted, I welded them solid.
Old Jul 6, 2012 | 04:29 PM
GreatNorthWoods's Avatar
GreatNorthWoods
I used 73-77 T-Bird motor mounts for the 302 in my 49...
Old Jul 6, 2012 | 05:14 PM
rhopper's Avatar
rhopper
No pics, I'm at work. Chassis Engineering bolt in mounts for F1's that use the old style rubber donut mount.
Old Jul 6, 2012 | 10:24 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle
This picture has some ugly vertical welds, but might help you see where, on the JAG ifs and the frame, mine are. This is passenger side.
Old Jul 6, 2012 | 10:32 PM
Jeff and Nicolle
If you have issues with your oil pan and your 289 will accept it, find an oil pan from a 5.0 explorer if possible. They fit the JAG really nice. Of course everybody has a little different location. some mounted higher or lower, more forward or back. Pay attention to the rear of your drivers side head. it sits back farther than the passenger side. Mine clears by about 1/2". I would prefer a little more, but...here is a pic of the pan.
Old Jul 6, 2012 | 10:34 PM
Jeff and Nicolle
These mounts look alot easier than my fabbed mounts!
Old Jul 6, 2012 | 10:52 PM
Jeff and Nicolle
Here are a few more:
Old Jul 6, 2012 | 10:58 PM
Jeff and Nicolle
Hey Bill, I would like to see more of the mount that is welded to the frame. I wish I would have seen these pictures before I made my own...they really do look good! who make them/ sells them ?
Old Jul 7, 2012 | 12:10 AM
Holehawgg's Avatar
Holehawgg
I'm with Jeff. These look like a good simple mount to use. Where did you get them or did you make them?
Old Jul 7, 2012 | 12:13 AM
Holehawgg's Avatar
Holehawgg
Thanks for this Jeff. The motor is about ready to pick up from the rebuilders and I knew this was going to become an issue. I had checked the ones out at summit and I also read that some of the 351's had rear sump pans that would work. The more info the better...
Old Jul 7, 2012 | 12:34 AM
Jeff and Nicolle
No problem! I sent you a PM too.
Just stay away from the mid sump truck oil pans. they are too close to the rack n pinion. And IIRC..the 351W and 302 do not use the same pan.
any other questions for me, I will be glad to help! But I am not a JAG expert by any means, so if anybody else has input, please jump in.
Old Jul 7, 2012 | 12:39 AM
Jeff and Nicolle
What transmission? And whats your plan for a pwr steering pump?
Old Jul 7, 2012 | 06:51 AM
tractormanbill
tractorman
ford mounts
Jeff,
I have a 302 with coil front end in my 52. Rack power steering and got the pan off of something that had the rear sump.l l don't have a clue what to do about the P/S pump. I call the junk yards and they just laugh at me with all the pulley arrangements, mounts, etc.l that were used.
TractormanBill
Old Jul 7, 2012 | 06:55 AM
tractormanbill
tractorman
Ford mount
Jeff, The mounts are the simple mounts that everyone sells that have a 90 degree bracket that welds or bolts to the frame rail.
TractormanBill
