Which alternator??
Old May 21, 2008 | 07:09 PM
Pearlwhite94's Avatar
Pearlwhite94
Which alternator??
Hi! im running two twelves in my truck and the alternator is just not keeping up. I installed it and had to disconnect it cause i could hear my fuel pump not working properly and my lights were all dimming. Bronco graveyard sells a 170amp alternator for 195 for the 5.0 and 5.8 but i have the 300 big sixer. Can i use that alternator and modify anything or does anybody know of another alternator made for my little engine??
Old May 21, 2008 | 07:49 PM
mhg's Avatar
mhg
go to Ford Fuel Injection
read on the 3G alt.
Old May 21, 2008 | 07:55 PM
bluesman2333's Avatar
bluesman2333
If by saying you are running two twelves you mean dual 12 volt batteries, any stock alternator should keep up fine in a properly maintained vehicle. If you cobbled together connections and don't have identical batts, you will have problems with not charging or parasitic discharge. Go over your electrical system and find the bad or questionable connections including grounds and starter & alternator connections and get two matched batteries.
Old May 21, 2008 | 08:16 PM
Pearlwhite94
Oh sorry, i meant to say 12 inch subs....wrote the question in kind of a hurry.
Old May 21, 2008 | 08:21 PM
bluesman2333
Two sub woofers and amps? Yea, get a 200 amp alternator. If the charging system maintains 14+ volts with amps off, and goes down with amps on, it is a sign the alt is too small. Still, go over the connections and make sure everything is OK. Bad connections will kill the ability of the alternator system to feed the battery charging duty and the electrical load duty.
Old May 21, 2008 | 09:19 PM
Pearlwhite94
i had issues with a ground wire some guy sold me that wasnt really the thickness it said it was. Im using both ground and positive 4 gauge wire. Running only one amp but it is still a good 1600 watts at peak. (spend alot of time their) I have a capacitor because i was getting some whining noises from the alternator and the readings drop from 14 volts to about 12 when the subs hit. Checked all the wiring, battery wires are kinda bad so im going to change the ground on the battery and the positive on saturday with some new ones. I still want to get an alternator but as far as one that will bolt into my truck, i dont know were to look. I emailed a company and got a quote of over 500 bucks.....no thanks! Will one from a 5.0 fit my engine at all??? Thanks for the responses!
Old May 22, 2008 | 01:31 AM
archangel's Avatar
archangel
And if the cost of a high power alternator gives you sticker shock, you could fabricate up an auxiliary alternator mount and get a self exciting regulator add a one wire alternator straight to the battery.
There is some good Alternator info here.
OneWireAlternator
Old May 22, 2008 | 02:28 PM
Pearlwhite94
Ford F-150 TransDapt Alternator Bracket - 1977-1996 Ford F-150 - TransDapt T379455
hey does anyone know about this bracket? Its supposed to fit alot of different vehicles and engines. I talked to a tech guy and he said i could use it to fit a 5.0 alternator into my l6. Its kinda like a universal bracket but
i wanted to see if anyone had attempted this before and could drop some tips or advice on it.
