1978 - 1996 Big Bronco
Unusual hub?
Old Mar 6, 2013 | 03:45 PM
92NCBronco's Avatar
92NCBronco
Unusual hub?
What is this hub cover/nut and how in the world do I get it off? It looks like a normal 92 bronco auto hub from the outer cap but this part is 6 screws/lugs and is too big (2 3/4" across) for any of the tools I've tried. Any ideas?
Old Mar 6, 2013 | 04:50 PM
Southern Bronco's Avatar
Southern Bronco
That is the old ford auto locking hub. To remove it you need to remove the spring clip from the hub, take a pick or thin screw driver, find the end of the clip and work it out from the hub. While you are at it go ahead and replace the auto lockers with a set of manual locking hubs, and get a service manual if you dont have one already.
Old Mar 6, 2013 | 05:27 PM
92NCBronco's Avatar
92NCBronco
That'd be too easy. It doesn't have a spring clip. At least not externally.
Service manual (haynes) by the way gives me nothing for removing this outer hub lock. Autozone doesnt list the tool either. At least not for a bronco... I'm thinking it may be from a bigger dana axle. Its 2 3/4" or 70mm across.
Old Mar 6, 2013 | 05:29 PM
92NCBronco's Avatar
92NCBronco
This is the right size and number of lugs but I dont see how it would fit my hub.
OTC 1953M Locknut Socket,Metric,Points 6,70mm | Bizrate
Old Mar 6, 2013 | 11:08 PM
Torky2's Avatar
Torky2
Are you looking in the right place for the spring clip that Southern Bronco mentioned?
Look inside the hub (the hub that is connected to the rotor, not the auto locking hub) a ways in from the outer opening. On the inner diameter of the pipe-like hub part coming out towards you.
Old Mar 7, 2013 | 05:33 PM
deadeyedevon's Avatar
deadeyedevon
there right, the clip is there, a pick and small needle nose and you've got it. its right in side the outer lip of the hub. sometimes putting pressure inwards on the hub assembly makes it easier
Old Mar 7, 2013 | 06:44 PM
GruesomeJeans's Avatar
GruesomeJeans
Here is a picture of my 78 hub. You might be able to see the small groove just on the inside.
See if you can feel inside your hub for something like this if you could. If so, then you should have a ring in there. I don't know what brand those are but mine are Warn hubs. They could be similar.
That's the snap ring.
Old Mar 7, 2013 | 06:58 PM
deadeyedevon
the above sums it up, i believe on the later models its a rounded c-clip instead of the flatened version on the 78-79
Old Mar 7, 2013 | 07:57 PM
GruesomeJeans
https://www.ford-trucks.com/forums/1...l#post11243835
Here is a good write up of how to replace hubs. Encho made it.
Old Mar 8, 2013 | 01:36 PM
92NCBronco's Avatar
92NCBronco
OK so I looked past my nose (and a whole lotta grease) and found the snap ring (thanks guys) but I'm having a heck of a time tryin to fight it outta there with a pick and a small screw driver. I can barely access it with those and my 'needle nose' wont even get close. Any helpful tips? thanks
Old Mar 8, 2013 | 01:47 PM
deadeyedevon
best combo i found to do it is a medium flat head to hold one end of the clip in place and a hook end pick to get behind and under the other end, if that makes sense
Old Mar 8, 2013 | 01:51 PM
92NCBronco's Avatar
92NCBronco
that was my idea but i cant find my hook end pick! i've got to let people stop borrowing my tools haha
Old Mar 8, 2013 | 01:52 PM
deadeyedevon
yea, its always the borrowed ones you need the most, remember the less grease around the ring the easier it will be to remove
Old Mar 8, 2013 | 02:51 PM
GruesomeJeans
Ehh I guess we should have warned you that it is a huge PITA getting that damn thing out. I used a small screwdriver to slide in the groove till I hit the end, then pried it up and slid another to keep it up, then had the tip of the small screw driver bent a bit and used it like a pick to pull it put. It takes time and patients.
Aremee
Apr 2, 2016 10:16 PM
ericboj
15
Jul 6, 2014 09:18 PM
jcammarata
Feb 16, 2014 06:40 AM
tchad07
May 6, 2007 06:34 PM
jopey
Sep 24, 2000 03:11 PM
