1978 - 1996 Big Bronco
86 Bronco Hub Removal
Old Sep 18, 2000 | 10:40 AM
jopey's Avatar
jopey
Old Sep 24, 2000 | 08:22 AM
jk's Avatar
jk
Hi, I'm having trouble getting the hub off my Bronco, I removed the snap ring, but cant get the inner hub assembly out, Is there another snap ring in there
Old Sep 24, 2000 | 03:11 PM
billyb's Avatar
billyb
on these hubs, there is a lock ring that holds the hub body in the hub. you may need to clean grease and dirt out of way to see it. it fits in a groove cccut into hub. i use a small screwdriver to get under the end and work my way arond to remove. i am sure ford has a special tool for this for a lot of money!!!.
check repair manual for exploded view of part
aand follow directions.
hope this info helps.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
