96 f150 starting problems
Old Mar 6, 2013 | 11:49 AM
stevelom29's Avatar
stevelom29
So I replaces the starter and the fender wall solenoid a I went to reconnect the positive terminal the starter automaticly turns the truck over and the key is out the ignition and the ignition is off I checked all fuses and wires are all good
Old Mar 6, 2013 | 01:46 PM
stevelom29's Avatar
stevelom29
Anyone have any ideas
Yaga1973's Avatar
Yaga1973
Elder User - What???
Do you have it wired properly?
Old Mar 6, 2013 | 01:48 PM
stevelom29's Avatar
stevelom29
I put the wires on there the way it looks like it should be I've looked for pics and found none
Old Mar 6, 2013 | 01:59 PM
Yaga1973's Avatar
Yaga1973
Look at post #4: https://www.ford-trucks.com/forums/1...g-diagram.html
This is how your solenoid should be wired. Is that what you have?
Old Mar 6, 2013 | 02:18 PM
88n94's Avatar
88n94
If you have it wired correctly. I would remove the small wire that is hooked on the large post of the fender mounted solenoid that goes down to the starter. If it still cranks the solenoid on top of the starter is bad. If it no longer cranks the fender mounted solenoid is bad.
Old Mar 6, 2013 | 02:21 PM
stevelom29's Avatar
stevelom29
Nope I just wired it how this guy I got it from wired it
Old Mar 6, 2013 | 02:50 PM
Yaga1973's Avatar
Yaga1973
Well, if it is wired like the post in #4, then I would say either the solenoid on your starter is bad or the one you just bought is bad.
Old Mar 6, 2013 | 03:21 PM
stevelom29's Avatar
stevelom29
I fixed the wires but as soon as I try to put the positive terminal on it sparks and wants to engage the starter
Old Mar 6, 2013 | 04:58 PM
stevelom29's Avatar
stevelom29
Ok so im a hundred percent sure everything is properly wire I turn the key over the solenoid on the fender wall engages that's it
Old Mar 7, 2013 | 07:21 AM
stevelom29's Avatar
stevelom29
Old Mar 7, 2013 | 07:45 AM
rla2005's Avatar
rla2005
Some diagrams from my buddy SeattleFSB:
Holiver31
Mar 9, 2011 09:18 PM
Kongslibakken
Nov 6, 2009 09:25 AM
95f250
Sep 20, 2009 01:53 PM
bort99
Jan 14, 2008 11:47 AM
