Smoke
Old Mar 6, 2013 | 09:15 PM
chetspencer's Avatar
chetspencer
Take a look at the two videos in this post:
https://www.ford-trucks.com/forums/1...l#post12905575
Do the test as in the first video and hope it doesn't sound like the second video. If it cranks like the second one, injectors are not your problem.
Old Mar 6, 2013 | 09:34 PM
lomac9's Avatar
lomac9
No mine definitely sounds like the first. It starts and idles perfectly, just bogs down and smokes when you push pedal. Was told to buy a new fuel pump with that kinda pressures at idle, would a blue spring upgrade make that much difference with this type of problem? I really appreciate all the input.
Old Mar 6, 2013 | 09:41 PM
chetspencer
If your not getting about 65 psi with the Blue Spring, there is something wrong.
Old Mar 6, 2013 | 09:50 PM
lomac9's Avatar
lomac9
Thanks Chet. I haven't done the upgrade yet. It's just 45 psi at idle w/o touching pedal. Just gonna go down tomm and get pump and spring upgrade. Guess pump from dealer is the way to go?
aaron8669
Jun 26, 2018 01:40 PM
onequicksportster
Aug 19, 2012 09:34 PM
Fire Mechanic
Aug 7, 2011 10:10 PM
garsm
26
Jun 28, 2011 07:59 PM
knight60626
Nov 30, 2009 09:25 PM
