Transmission or motor problem??
Old Mar 5, 2013 | 09:18 AM
Kevin 1988's Avatar
Kevin 1988
I recently bought a 99 expedition that was running sluggish changed the plugs an wires discovered the intake was leaking so I replaced that cleaned the injectors an EGR ports an the transmission had a hard shift going into second I checked the trans fluid an it was two quarts over filled I pulled that out with a pump it still has the hard shift an if I try an power break it it will get to 3000 rpms an do nothing an suggestions
Old Mar 5, 2013 | 09:20 AM
Kevin 1988's Avatar
Kevin 1988
I've also read about converter problems could that be it
Miguel P
Aftermarket Products
Oct 19, 2018 05:51 AM
hotrodtodd
Oct 9, 2014 05:35 AM
flybeau
Dec 22, 2012 04:42 PM
Mud-and-Guts
Jan 3, 2010 06:15 PM
Jimmygunz3
Mar 31, 2007 04:57 PM
