Rear Leaf Spring Lowering Question
Old Sep 25, 2013 | 06:55 AM
gumshoe's Avatar
gumshoe
I have used djm on two of my trucks this will lower the truck about four in. I removed the thick bottom leaf also. I used 4 degree shims. you have to space the center bolt to go thru the shims, add spacers on top of the u bolts if you remove the lower thick leaf. and yes it is a hard job to drill and grind the rivits out. be easy if the bed was off
Old Feb 12, 2018 | 12:31 PM
bull jr's Avatar
bull jr
To revive an old thread, HIO Silver threw out the idea of partnering the DJM lowering kit with the Eaton lowering leaf springs. I couldn't find on here anywhere that someone has tried that. I decided to give it a try. It works! I was able to get the rear of the truck down an additional 3 inches doing so, and with new leaf springs. I went with their 3 pack springs, but they have options. They also offer lowering front coil springs. I called and spoke to them, they say it won't affect camber but I can't believe that to be completely true. Anyway, thought I'd throw some new info out there for the next guy looking for some help!
johnson.jeff.a
Aug 22, 2016 04:24 PM
nick5446
Sep 9, 2014 12:52 PM
Pappys53
May 29, 2011 02:00 PM
55 f350
Aug 21, 2007 04:31 AM
danfish
Feb 21, 2007 01:32 PM
