Considering a couple different swaps
Old Mar 4, 2013 | 10:17 AM
Jarryd's Avatar
Jarryd
I have 2 different directions I've considered going but don't know what I want to do yet.
Option 1: carb 351/408w, I could drop it in without changing much of anything and I'm pretty sure it will work with a regulator to drop fuel pressure.
Option 2: efi 351/408w, same as above but I'll have to get the 302 computer and wiring harness and throw in a tune for the new engine
Option 3: coyote swap with frpp PCM kit. Should be relatively simple to wire but I don't know how to address the engine mounts and what tranny to use so I could still have a manual.
These would all be replacing the 300 six in my 94 f150.
Old Mar 5, 2013 | 10:15 PM
Jarryd's Avatar
Jarryd
I also happen to have a built navigator 5.4 4v engine laying around that I had other plans for and never used. Could I use a navi computer and engine harness and make this thing work?
Old Mar 7, 2013 | 10:10 AM
Conanski's Avatar
Conanski
A 351EFI with a few tweaks is a massive upgrade from the 300slow and you won't have to change the whole powertrain and every last wire on the truck to make it work.
Old Mar 7, 2013 | 10:18 AM
Jarryd's Avatar
Jarryd
That's what I was thinking. Figured a high compression 351 or stroker with some trick flow heads and intake would be fun.
Ddaybc
Oct 15, 2014 06:11 PM
Oxfordrider
18
Jul 30, 2013 07:50 PM
Hitokori
Nov 28, 2009 07:30 PM
hicks_nolan
Jul 19, 2007 02:36 PM
GhostRider32
Engine Swaps
Jun 13, 2005 05:18 PM
