E-fuel question???
Old Mar 4, 2013 | 09:11 AM
stealthrunner's Avatar
stealthrunner
Question E-fuel question???
Got a efuel question for all you OBS guys....i saw some where in a efuel thread some where....and i'm after the fitting/fittings that are used to adapt an AN line to the banjo fitting in the valley to the hard lines that go to the back of the heads on my 95 7.3 obs...
and one about the fuel lines on top of the motor...
Which lines of the lines the hard lines to the back of the heads or the braided lines that hook up to the FPR are the return lins back to the tanks????? Thanks for any info!!! starting my e-fuel conversion in 2 days after figureing out my new AE program!!!!
<!-- / message --><!-- sig -->
Old Mar 4, 2013 | 03:18 PM
427 fordman's Avatar
427 fordman
Welcome to fte. I'm no help on the banjo fitting, I eliminated mine, but the lines to the back of the head are pressure, the front are return.
Old Mar 4, 2013 | 06:11 PM
stealthrunner
Question
Thanks 427 ford man!!! Any body Know which E-fuel build it was???
I think it could have been a large AN fitting that the banjo bolt screwed into???
Old Mar 4, 2013 | 07:59 PM
Splatts's Avatar
Splatts
I did the same. I used a y block from summit and these to connect to the hard lines on the back of the heads
Don't know what they are called or the exact size. But it a 3 piece fitting. I just told the guy I need to connect this to this. Whatcha got? Hope that helps.
Old Mar 4, 2013 | 09:06 PM
stealthrunner
Thumbs up
Thanks for the info!!
Old Mar 4, 2013 | 09:20 PM
Redneckmorton's Avatar
Redneckmorton
The kit I bought has an adapter to go from the Banjo bolt to a smaller thread to a 3/8" barbed fitting, then the 3/8" hose just slide on to it. But I'm not sure what it was.
If you wanna reuse the Banjo bolt. Pull it out and bring it to the hardware/parts house and find something that will fit.
Old Mar 4, 2013 | 09:25 PM
stealthrunner
Thumbs up
Good idea we have a few Hydralic shops where i live!!!
Old Mar 12, 2013 | 02:46 PM
stealthrunner
Question
One last question before i go over to the shop and start cutting into lines to route fuel to my pre and post filters and get the truck running again....
Which hard line on the frame upper or lower is the line that carrys the fuel to the motor from the Pump????Got the return line all routed already!!!!
Now for getting the pump and filters all hooked up!!!
Old Mar 12, 2013 | 03:46 PM
Redneckmorton
Typical installation will have it as the lowest line of the group. Or at least that is the instructions that came with my kit and it was right on my truck. Best thing to do is to have someone help you follow it out just to make sure.
HAVE A BUCKET OR SOMETHING TO CATCH THE FUEL WHEN YOU CUT THE LINE. Also its best to have a empty or near empty tank when doing so. Cause when you cut the line, fuel WILL pour out until your out of fuel in your tank. So be ready to work quick once you get there. Have everything lined up and ready to go.
Old Mar 12, 2013 | 05:11 PM
Awitte58's Avatar
Awitte58
Why will fuel pour out until the tank is empty?
The fuel on our trucks (stock fuel system) is pulled to the front from the tank.
So with the truck off...and you cut a line only the fuel in the lines would just dump and thats it?
Old Mar 12, 2013 | 08:59 PM
Redneckmorton
Here is what the instructions that I had said.
"Just as a note when you cut the factory hardline, it is imperative to have a near empty tank or even better a totally empty fuel tank selected with the fuel tank selector switch. Once you cut the line gravity and vacuum will take over and result in diesel spilling onto the ground from the hardline."
Old Mar 12, 2013 | 11:05 PM
stealthrunner
Wink
Thats what a bolt that fits in the fuel line is for!!!
Old Mar 13, 2013 | 02:49 AM
stainlessstroker95's Avatar
stainlessstroker95
I didnt have fuel everywhere when i did my e fuel.
Biggreen71250
Feb 16, 2016 01:15 AM
Blue7.3
Australia Chapter
Sep 21, 2014 07:01 PM
r-kid
18
Jan 19, 2014 03:11 PM
Ford4Life7.3
Dec 22, 2013 01:07 AM
lazerf250
Feb 21, 2009 09:01 AM
