1997 explorer 4.0 x
Old Mar 3, 2013 | 03:54 PM
danielnw78's Avatar
danielnw78
1997 explorer 4.0 x
Not sure if I am doing this right. I have a 97 explorer 4.0 the engine will get to operating temp at idle as soon as u give it throttle the temp starts falling I have changed the t stat,temp sender & ect the heat doesn't work very well the blend door and actuator work fine and full of coolant any help would be appreciated
Old Mar 4, 2013 | 04:52 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
Welcome to FTE!!
Moving to correct forum.
Old Mar 4, 2013 | 06:30 AM
shorod's Avatar
shorod
Welcome to the forum!
Did it have this issue before you changed the any of the cooling system parts (thermostat, temp sender, and ECT)? Maybe you have air trapped in your cooling system.
-Rod
Old Mar 4, 2013 | 08:30 AM
KhanTyranitar's Avatar
KhanTyranitar
what brand t-stat did you use?
Old Mar 4, 2013 | 01:54 PM
danielnw78's Avatar
danielnw78
Yes I had this problem before changing parts. I used a ford t stat I took it apart because of the way it acted. Took the ford t stat back out tested it with hot water worked fine put it back in still the same. I have a vacuum filler so I don't think air is trapped
Old Mar 4, 2013 | 10:46 PM
KhanTyranitar
Testing a thermostat in hot water does not confirm it is good. A thermostat opening and closing is a static evironment without being under pressure is quite different from an environment when it is under 16 psi pressure and the flow and pressure from a water pump.
That being said, maybe your can clutch is bad.
Old Mar 6, 2013 | 08:29 PM
Graygeorge's Avatar
Graygeorge
Do both heater hoses get hot or warm? If not, try back flushing the heater core/
Old Mar 7, 2013 | 06:12 PM
danielnw78's Avatar
danielnw78
I am going to flush the heater core this weekend.been trying to do it but had a bunch of snow the last 8 days
Jasontt
Jul 5, 2017 11:31 AM
ccarey731
Jan 12, 2011 05:42 PM
lboze
Electrical Systems/Wiring
Dec 6, 2003 04:10 PM
wislow
Aug 8, 2002 11:42 AM
