Please explain: 10k Resistor Mod
Old Jun 1, 2003 | 02:35 PM
tanglewood's Avatar
tanglewood
Exclamation Please explain: 10k Resistor Mod
CAn anyone tell me what this is? Or provide a link to how/what to do...
I've heard that you can trick the sensor that looks for smoke in the exhaust/tail pipe with a resistor to gain HP.
Is this it? Or is this something entirely different?
Thanks!
Old Jun 1, 2003 | 02:59 PM
jschira's Avatar
jschira
The mod is to put a resistor in the ICP circuit, the higher the resistance, the higher the injection pressure.
Old Jun 1, 2003 | 07:16 PM
tanglewood's Avatar
tanglewood
So is this the sensor that is in the tail pipe that checks for smoke/smog?
What type of gains can be expected? Good and points?
Is there a page out there that has instructions on this mod?
Thanks...
Old Jun 1, 2003 | 08:43 PM
jschira's Avatar
jschira
Nothing to do with exhaust, it increases your fuel injection pressure.
Old Jun 2, 2003 | 02:12 AM
SouthernDually's Avatar
SouthernDually
Question Please explain: 10k Resistor Mod
For a simple mod that looks fairly complicated. jschira you said that it just tricked you intake into raising the injection pressure. What would be the advantage of that over a programer. It looks like its a little too much for the average type person.
Old Jun 2, 2003 | 05:59 AM
jschira's Avatar
jschira
There are a lot of vendors who sell boxes and programmers that do much the same thing. The difference is that the 10K mod can be built yourself for less than $10 in parts versus $100's for a box from a vendor.
Old Jun 2, 2003 | 08:13 AM
tanglewood's Avatar
tanglewood
Are there any published gains this gives? I wouldn't think it's worth all that for a mere 5 ft/lbs or HP....
Old Jun 2, 2003 | 08:57 AM
jschira's Avatar
jschira
I think that it is more of a driveability mod rather than a great generator of HP.
I think that some of these posts discuss pros and cons, what to expect.
If you are looking for HP and torque, a chip or a programmer will give you a better result and most will include a 10K mod-like improvement.
The 10K mod was/is intended as a quick, cheap DIY kick in the pants.
Old Jun 2, 2003 | 06:11 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The 10K mod dosen't need switches or rheostats or anything else. These are things that are added to make it adjustable, and to switch it off at idle.
If you just want to try it out to see if you like it you can simply take a 10K ohm resistor and push it into the plug for the ICP sensor. No need to build anything.
On a stock truck the 10K is said to make around 20hp. On my not stock truck the 10K added 8hp, and 32lbft of torque. Not too shabby for a $0.21 mod.
Poolguy601
Dec 21, 2012 09:35 PM
mtnone
Oct 14, 2012 09:20 PM
jadel
Mar 7, 2005 09:05 AM
wssess_ford
Aerostar
Jul 8, 2002 01:47 PM
alacooney
Feb 17, 2001 01:49 AM
