EBP valve resistor
Old Dec 21, 2012 | 04:34 AM
Poolguy601's Avatar
Poolguy601
EBP valve resistor
Is there a resistor that can be installed at the plug so when it is unpluged at the turbo it wont set a code??
Old Dec 21, 2012 | 11:18 AM
timmyboy76's Avatar
timmyboy76
470k 1/4w resistor.
Old Dec 21, 2012 | 04:29 PM
mueckster's Avatar
mueckster
Originally Posted by timmyboy76
470k 1/4w resistor.
It's a 470 ohm 1/2 watt (can be found at Radio Shack). Some prefer a 1 watt, if available, but the 1/2 watt has been in my truck for several years with no problems.
Old Dec 21, 2012 | 04:41 PM
Poolguy601's Avatar
Poolguy601
Do you just make a connection across the plug terminals
Old Dec 21, 2012 | 04:48 PM
Edogsf350's Avatar
Edogsf350
Will this create. Boost faster from a stop
Old Dec 21, 2012 | 06:42 PM
1fixitman's Avatar
1fixitman
This is how I did mine and documented it.
https://www.ford-trucks.com/forums/1...e-install.html
Old Dec 21, 2012 | 07:10 PM
mueckster's Avatar
mueckster
Yes. Some cut off the plug and solder it to the wires, others bend the ends and install it into the plug terminals. See 1fixitman's link in the previous post.
No. It is simply used to eliminate soft codes that are stored by the PCM due to the EBP solenoid being disconnected.
Old Dec 21, 2012 | 09:35 PM
Poolguy601's Avatar
Poolguy601
Thank you guys.
jyates2007
Oct 18, 2015 11:24 PM
Chipworkz
Apr 21, 2013 10:37 PM
DCook909
Apr 15, 2013 11:19 AM
mongo12
Dec 3, 2010 12:29 AM
F250_
Jan 7, 2010 09:48 AM
