Heater switch resistor
Old Oct 11, 2011 | 09:13 PM
mtnone's Avatar
mtnone
Hi all.
The switch for the heater in my 1966 f100 is missing. I see from the wiring diagram that it is just a simple switch with a resistor inline for low speed. Since I can not find the switch for sale easily, I was just going to make a new one, maybe even install a variable resistor dial for multiple speeds. Does any know what size resistor was in the original switch?
Thank you.
Old Oct 11, 2011 | 10:06 PM
camperspecial65's Avatar
camperspecial65
Is your heater a deluxe or standard heater??? I have a switch/cable setup for a deluxe as well as a resistor...which are located on the heater case itself.
- cs65
Old Oct 12, 2011 | 06:59 PM
spurredon's Avatar
spurredon
I repaired one in an older C***y one time by taking a paper clip and twisting it to resemble the existing rotted one and was able to solder it back in to bridge where the original had broken. I didn't think to take a reading at the time but it could not have been much more that an ohm, perhaps less. It was for the middle speed.
Old Oct 12, 2011 | 08:29 PM
mtnone's Avatar
mtnone
At this point I not sure it matters if its deluxe or standard. When I got the truck it had already been stripped out. I have the basically two wires coming out of the heater motor and a lever on the defrost/floor vent box.
I think just a simple 3-way switch could be the simplest answer.
Old Oct 12, 2011 | 09:43 PM
OldHarley's Avatar
OldHarley
mtnone,
FYI, you have what is known as the economy fresh air heater.
It is not a simple switch. It has a cable you pull for heat and the switch part rotates to turn the fan from off to high or low.
Old Oct 12, 2011 | 11:56 PM
camperspecial65
Ok... I have one for you if you are interested... Post your email and I will reply with pertinent info on the switch.
- cs65
Old Oct 13, 2011 | 08:46 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C5UZ-18578-A (replaced switches marked C5TA-18578-C & D *) .. Heater Switch/Cable Assy / 30.25" O/A length / Obsolete
Applications: 1965/66 F100/1100 with Deluxe or Economy * Heater / 1965/67 Econoline.
The switch does not include the ****, bezel, retaining nut, U shaped mounting bracket and the clip & screw that attaches the switches Bowden cable to the heater box, all of which are prolly missing on the OP's truck.
* This switch replaced the Economy heater switch that was 24.75" long (1965/66 F100/250), 28.75" long (1965/66 F350/1100).
C5TZ-18591-A .. Heater Blower Motor Resistor / Obsolete
Applications: 1965/67 F100/1100 & Econoline / 1965/69 N/NT/T500/1000 / 1968/69 F800/1000.
Note: The Economy heater has a manually operated shut-off water valve (C5TZ-18495-A -obsolete) that is spliced into the inlet to heater core heater hose.
The Deluxe heater has two cables mounted to a bracket, that bolts to the bottom of the dash...to the right of the steering column.
One cable opens/closes the damper door that allows fresh air to flow into the heater box.
T'other cable opens/closes the heater water valve (C3UZ-18495-A -available from Ford) that is spliced into the inlet to heater core heater hose.
Old Oct 14, 2011 | 03:02 AM
camperspecial65
I have the whole switch/bezel, etc tamale...The resistor itself is on the heater case on the topside of it.
- cs65
Old Oct 11, 2012 | 02:13 PM
65F100390's Avatar
65F100390
Exclamation Heater blower motor switch, HELP IT IS COLD!
Does anyone have any of these parts available, or know where I can get one, winter is hitting in Montana and mine just broke. The cable is working to push/pull the manual valve open, but the twist portion of the know that controls the blower motor has failed. Can you jump it as a temp fix until the part arrives? Please let me know as I need the defroster more than anything. Thanks!
Old Oct 12, 2012 | 07:46 AM
NumberDummy
The cable is working to push/pull the heater plenum chamber 'flapper' valve open, but the twist portion of the **** that controls the blower motor has failed.
The **** doesn't come with the cable, furnished by itself. It's retained to the shaft of the combo blower switch/temp cable by a set screw. Verify the screw is tight, otherwise the **** will just spin around.
C5UZ-18578-A .. Combination Heater Blower Switch/Temperature Control Cable - 30.25" long / Obsolete
This was a FoMoCo "service part replacement" for the original factory installed switch/cable. On some applications, it may have to be "cut to fit."
Applications: 1965/66 F100/1100 / 1965/66 N/NT/T500/1000 / 1965/67 Econoline / 1967/69 F800/1000.
There is only ONE of these cables available NOS
Old Oct 14, 2012 | 09:20 PM
deansbuild's Avatar
deansbuild
I found these at LMC in Kansas, Lenexa, $14.95 fits my 1965 f100 great works great, hope helps
Tegan
17
Oct 1, 2022 02:32 PM
SpedKid94
May 18, 2015 04:54 PM
Englishbob
Nov 21, 2011 09:06 PM
stumpbuster
Dec 12, 2007 12:09 PM
