yeah empty again i would get away. no car fax no accident report even tried the on one the forum that tells you engine type where its made and such and nothing, seems like a scam
Wow,which did you try,CarFax or Auto Check?
The VIN on the dash and the door sticker both have that number and I know the current owner quite well.
Thanks for trying.
i tried both and the one on this forum and came up with nothing however i can tell you that its made in america and has a GVWR of 6001 to 7000 pounds, 2wd single cab long bed with a 5.0 302 motor its a 1990 or a 1994 it was made in Wayne michigan and it was the 47269 truck off the line for that year
Paint Code: XD
Trim Code: DK
Gross Weight: 6,250lbs
2THJ NOT DEFINED
F1TAT NOT DEFINED
F4TAE NOT DEFINED
AAAAD XLT VERSION
AAGAP MICHIGAN PLANT BUILT
AAMAB CONVENIENCE GROUP
ABKAB POWER EQUIPMENT GROUP
AC0B0 MANUAL AIR CONDITIONER
BHEAB WITH NOISE INSULATION PACK
BLDAB CHROME-PLATED
BMLAE LOWER B/S MLDG
CLMAE REAR BUMPER-STEEL STEP-CHROMED
CLVAB FRT LICENSE PLATE BRKT/HOLDER
D2SEY 7 1/2J X 15 DEEP DISH WHEEL
D3GUB P235/75R15XL BSW A-S
EGAHD 3.55 FINAL DRIVE RATIO
EGJAB NON-LIMITED SLIP REAR AXLE
EGLAB FORD/VISTEON AXLE VENDOR
EJADR 3800 LB(1724 KG) REAR AXLE ASSY
EM0C0 CALIFORNIA REQUIREMENTS
EN0VP MOD 4.6L SOHC EFI NA V8 CNG
GBCAB WITH AUXILIARY FUEL TANK
GRAAC TILT STEERING WHEEL
GTDAB SPEED CONTROL
IBAAG ELECT AM/FM/STEREO/CASSETTE/CLOCK
JCBAB AMBIENT LIGHTING
PNCXB TUSCON BRONZE
TR0DU 4 SPD AUTO TR NAAO AODEW/4R70W
*Edit: Just ran it on AutoCheck. They found the VIN and there's 20 records for it. I don't have a membership so I can't tell you more than that.
I had a very bad experience with Carfax. I bought a car off a private party that carfaxed so clean carfax said it was worth above retail. Well after one year $9,000 in repairs, ASE mechanics that were willing to put into writing that this vehicle had way more miles than Carfax said. That the vehicle had been in an accident.
carfax is a waste of time & money. When I went back on carfax they said they would refund my $39.
Craig
Thank you Gents for both the efforts and the report!
I had a bit of a problem with both CarFax and Auto Check @5 years ago,it seems both gave a clean bill of health on a car but later I discovered the header panel was damaged (cracked) and the car must've been in a real low speed shunt.The owner must've ate the cost of repairs and never reported it to either her insurance or the cops so it didn't show up.
Being as it wasn't reported to either the insurance or cops I really couldn't fault CarFax or Auto Check,my insurance agent was a real whiz and he couldn't find any reports either AND he discovered the woman had the same insurance company I had.
