I am phil I am trying to figure out this raw sweet burning scent coming from my vehicle mainly when running I am aware that my tranny is leaking
Onto my exhaust headers my truck is very run down body wise but its a rebuilt engine but it also reaks as if it was something else. My system seems to be a fluzy though soft but hot hoses. Brown in the radiator wentr from green to brown idk my temp is accurate though
brown in the radiator would be oil- likely meaning that you're also getting coolant somewhere its not supposed to be...like burning in a cylinder, producing a sweet smell.
since you have the funny smell
easy way to check , replace your spark plugs , make note of what came out of where . the one that's the problem ,( or more than one )will be different most likely caked with a weird color stuff .
