General Automotive Discussion
car overheating
Old Sep 30, 2007 | 10:29 PM
SasquatchF-250's Avatar
SasquatchF-250
car overheating
alrighty,
i have a 1994 mercury cougar with a 4.6 V8. it started over heating. I'm thinking that its the water pump but there was no explosion of coolant, no leakage. However, the coolant reservoir was filled/over filled...mind you the coolant was at the proper level last time i checked.
so any ideas?
Old Oct 1, 2007 | 12:34 AM
ford2go's Avatar
ford2go
Radiator cap ( good)
Head gasket ( bad)
I'd replace the radiator cap and check the following:
oil for antifreeze (smell?)
antifreeze for oil (milky?)
pop radiator cap shortly after running -- if 'pop' sseems excessive may indcate head gasket ( overpressure of cooling system)
ford2go
Old Oct 1, 2007 | 07:26 AM
osbornk's Avatar
osbornk
Make sure the radiator is not stopped up or a radiator hose is collapsing. When the car is hot, check to see if the center of the radiator is as hot as the engine. I've ran into a stopped up radiator several times (particularly MOPARS)
Lonewolftx
Mar 15, 2017 11:52 PM
damicofuel
41
Feb 24, 2014 06:31 AM
spunout
6.4L Power Stroke Diesel
66
May 11, 2012 09:10 PM
Nitrous
Oct 22, 2010 06:50 AM
84-250
May 18, 2008 03:25 PM
