How Important is Spark Plug Gap???
Old Mar 2, 2013 | 12:01 AM
kermmydog's Avatar
kermmydog
Smile
Originally Posted by Andrew James
I meant, when you pulled the old plugs out how large was the gap?
A little over an 1/8th of an inch. Around .125-.150 No plug gap tool big enough. Had to use a ruler.
Craig
Old Mar 2, 2013 | 09:40 AM
BigBlockF350's Avatar
BigBlockF350
Spark plug gaps can matter for efficiency. Generally the gap getting larger doesn't affect that too much.
I recently played with different gapped spark plugs in my 460. The ones I pulled out were worn to about .066 (they started at .045), I threw in a new set of .045 gapped plugs. Drove it a bit, and I immediately noticed better torque. I got the same 10.3 MPG out of a tank as normal. Then I threw in some .035 gapped plugs (stock for engine). I had a little less torque, but I ran a tank of gas at 8.9 MPG with my normal driving.
So for gap mattering, from what I saw, MPG is worse with a gap too small. The bigger gaps had the same MPG in my case (new 0.45 plugs and the worn .066 plugs). As far as it running okay, I don't think it matters what gap it is, it'll start and run. Heck, I think I could run a wire hanger through some JB Weld and stick it in there and start it up... lol
Old Mar 2, 2013 | 03:19 PM
Opossum's Avatar
Opossum
Gap, bigger is better until it's too big
It really is that simple, go big until you no longer have the juice to spark it. Then shrink the gap or get more juice to the plug. Bigger gap means fewer missfires on leaner mixtures meaning more power and more MPG.
F-250 restorer
Jul 28, 2013 10:10 PM
aspellicy
2004 - 2008 F150
Mar 1, 2007 03:58 AM
4.9inline6
23
Oct 25, 2005 11:07 PM
stirfrysteve
1983 - 2012 Ranger & B-Series
Feb 27, 2005 03:22 PM
Pastmaster
Mar 10, 2002 07:15 PM
