How Important is Spark Plug Gap???
Old Mar 1, 2013 | 08:53 PM
kermmydog's Avatar
kermmydog
Question How Important is Spark Plug Gap???
I found out today Spark plug Gap isn't very important. I changed the Plugs in my 95 F150 4x4 302. To my surprise the plugs in it were the original factory plugs. They were never changed since new. This truck has 138,400 miles. Since changing the plugs I notice no difference in performance or starting. With the OEM plugs I got 19.5 mpg. @ 65 mph this truck has a 5 speed. Monday I will see if I gained or lost mileage with new plugs.
I won't tell you guys the gap on the original plugs right now. I want to hear what you guys have to say & what do you think the plugs gap was?
Craig
Old Mar 1, 2013 | 09:07 PM
Immortal_Ben's Avatar
Immortal_Ben
How do you KNOW the plugs were factory? The gap on long-used plugs will be larger than when they were gaped and installed new. That is the nature of how a spark plug works.
Old Mar 1, 2013 | 09:18 PM
88n94's Avatar
88n94
I'll play your guessing game and bet I'm pretty close. .070 to .075.
Old Mar 1, 2013 | 09:38 PM
OldGrayFord's Avatar
OldGrayFord
.085 is my guess
Old Mar 1, 2013 | 09:48 PM
JWC 3's Avatar
JWC 3
The wider the gap past spec , the harder the ignition system has to work . The gap , is a set point . That gap will expand with with wear . A tiny bit gets worn away with each plug firing . Too small a gap can also cause issues just as too wide a gap . That said , modern ignition systems are much more forgiving than old point systems . I have seen .080 or more on worn plugs , with no complaint .
Old Mar 1, 2013 | 09:49 PM
kermmydog's Avatar
kermmydog
Smile
Because if you research you will find a BF42 was the factory plug. They don't even use that number anymore & from the looks & condition of the outside & gap. All the hoses, shocks, suspension parts, exhaust parts are all original.
Anyway since you guys took a guess I will tell you. The gap was over 1/8th of an inch. Around .125-.150". I kept on of the plugs & if I get a chance I'll post a picture.
Craig
Old Mar 1, 2013 | 09:53 PM
Immortal_Ben
Craig
Wanted to let you know I wasn't challenging you. I was curious how you knew, is all. I should have worded it better, sorry.
That s a crazy dang gap. I always keep my last couple sets of plugs, as I think they can tell me a story over time of what is going on in my engines.
Old Mar 1, 2013 | 10:24 PM
kermmydog's Avatar
kermmydog
Smile
Ben, no problem I didn't mean to sound challenged by your question I was just explaining how I knew. Maybe I should of worded it different.
Anyway all is good here with me.
They were all burning clean. The exhaust on this truck is clean also in fact the end of the tailpipe has a rust color.
Craig
Old Mar 1, 2013 | 10:30 PM
Andrew James's Avatar
Andrew James
Maybe someone had bought a some new old plugs. Motorcraft BF42 are the same as Autolite BF42, and I think I have some on my shelf right now.
Immortal_Ben
Everything is groovy, man.
Old Mar 1, 2013 | 10:58 PM
kermmydog's Avatar
kermmydog
Smile
I know the 3 people who owned this truck & the only one that would have a set of new/old stock is my buddy I bought it from & in 8 years he owned it he never changed the plugs.
If you look up Motorcraft plugs for this truck they call for SP450, (SF42CF4) Autolites are AP25.
Craig
Old Mar 1, 2013 | 11:42 PM
88n94's Avatar
88n94
With that kind of gap 138,000 miles would be short I would think. My '94 F-150 had 194,000 miles when I changed the plugs. It had Motorcaft plugs so I thought they were probably the originals. I bought it with 140,000 miles with no known history. Those plugs had a gap of about .090. Starting out at .044. That's how I came up with my confident, but inaccurate, guess under #3.
Old Mar 1, 2013 | 11:44 PM
Andrew James
Part numbers change, when I'm at work tomorrow Ill cross-reference them. What was the gap on the, again as of current?
Old Mar 1, 2013 | 11:54 PM
kermmydog's Avatar
kermmydog
Smile
.054 is the gap called for. I put a set of platinum Autolites AF25 in.
Craig
Old Mar 1, 2013 | 11:55 PM
Andrew James
I meant, when you pulled the old plugs out how large was the gap?
