Boost leak from Sensor on Spider????
Old Mar 1, 2013 | 04:21 PM
whargraves's Avatar
whargraves
Hey Guys, I decided to check for boost leaks just for good measures. While checking I found a leak from the sensor in the bottom of the spider. I have searched the forum and can't seem to fiqure out what this sensor is. The air leak is out of the sensor itself NOT the threads. The sensor is the one on the bottom not the AIH.
What is this sensor called and what does it do and is it one that can eliminated and plug.
Thanks a million
Old Mar 1, 2013 | 05:04 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Thanks a million
Sounds like you are talking about the air charge temperature sensor.
The little elbow fitting that has a hose for the MAP sensor can sometimes leak as well. I've actually seen cases where those just fall out of the spider.
Old Mar 1, 2013 | 06:06 PM
whargraves's Avatar
whargraves
Yes that's the one. I did see where the little hose was leaking and I was able to fix that. So I guess I need to fiqure out if I need to replace the sensor or just plug it.
Cell's
Apr 3, 2022 10:56 PM
lkbrow1
Sep 12, 2017 10:14 PM
SaintITC
Dec 1, 2013 11:17 AM
bryanlindborg600
19
Jul 27, 2011 08:43 AM
huronwoods
Nov 16, 2009 08:05 PM
