tpms sensor failure, leaking air
Old Sep 12, 2017 | 05:22 PM
lkbrow1's Avatar
lkbrow1
I have now had 4 sensors fail and start leaking air. The sensor is still accurate but the dealer is replacing them and it fixes the pressure leak.
I have an F350 dually with aluminum rims. The first failure occurred on the front passenger tire at about 8000 miles. It leaked about 10 psi per day.
After that sensor was replaced, the new one leaked at about 2 psi per day.
Now at 9000 miles, the rear outside drivers side is leaking at 30 psi per day.
and 2 days later the rear outside passenger side is leaking at 5 psi per day.
the leaks start suddenly and don't stop until the sensor is replaced.
Old Sep 12, 2017 | 06:41 PM
lotsofords's Avatar
lotsofords
I too have had that problem. My first sensor failure (no leak) was the rt rear inner and then had a leak at the right front.
DRW Platinum
Old Sep 12, 2017 | 10:14 PM
Nimrod's Avatar
Nimrod
I have a failure in my front right but only after about 3 hours of driving. Never see an issue other than that. No leak just bad sensor readings in that one rim.
whargraves
Mar 1, 2013 06:06 PM
bryanlindborg600
19
Jul 27, 2011 08:43 AM
mommadiesel
Dec 9, 2009 07:42 PM
huronwoods
Nov 16, 2009 08:05 PM
StampedePSD
Dec 8, 2008 02:36 PM
