Voltage Problem, reverse problem
Old Mar 14, 2013 | 12:54 PM
orionambulance's Avatar
orionambulance
So there is one battery in the engine compartment and 2 in a slide out tray on the side of the ambulance. Those two on the side are wired in series and I'm not sure where they connect to. I do know there are no special switches or anything, so all 3 batteries charge off the alternator without any human input.
Old Mar 14, 2013 | 12:56 PM
orionambulance
Yes they were on a cold start so I guess I should try and let it warm fully then check again. Also, I've posted on other forums like you suggested with no replies from anyone
Old Mar 14, 2013 | 04:30 PM
madpogue's Avatar
madpogue
The two in series makes, effectively, one 24V battery. Those must be for the rescue equipment in the box of the ambulance. So either that alternator has to be a 24V alternator with a step-down in-line somewhere between it and the engine battery in order to charge it, or there's a step-up somewhere between the alternator and the equipment batteries. TBH, I don't know what the voltage reading at the alternator output should be with such a configuration.
This also implies that the truck is being started by a single battery. There are supposedly some high-end AGM batteries capable of starting our engines single-handedly; it'd be interesting to know the chemistry and CCA capacity of that battery.
It would also be interesting to measure the voltage of the two equipment batteries together, that is, from the positive of the "first" battery in the series to the negative of the "second". Again, wait 'til after the glow plugs have cycled off.
Old Mar 14, 2013 | 06:18 PM
orionambulance
I apologize for that, I should have clarified. The entire system is 12 Volts. All batteries are regular Johnson Controls manufactured 12 volt 65 series batteries.
Old Mar 14, 2013 | 06:36 PM
fordpride's Avatar
fordpride
If the batteries are wired in series then they are putting out 24v
For them to put out 12v they would be wired parallel
Old Mar 14, 2013 | 06:37 PM
fordpride's Avatar
fordpride
Connecting Batteries in Series or Parallel
orionambulance
They must be parallel then. They go negative to negative, positive to positive.
Old Mar 14, 2013 | 08:45 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That is parallel.
Old Mar 15, 2013 | 04:14 AM
tjc transport's Avatar
tjc transport
i ain't rite
check voltage at the wires going into the gauge.
i bet you will find the gauge is bad.
my mack gauge shows 16.2 volts but is only receiving 14.2volts. i just never get around to changing it.
Old Mar 16, 2013 | 07:11 AM
orionambulance
The problem is the gauge is actually a display on the ambulance module which controls all the lights and whatnot.
1993 ford
Jun 16, 2017 04:40 PM
jrodjared
May 23, 2015 08:45 PM
Smirks90
13
Nov 1, 2014 05:11 PM
gpyles01
Dec 24, 2007 02:53 PM
_superduty_
1978 - 1996 Big Bronco
Feb 16, 2003 01:26 PM
