1978 - 1996 Big Bronco
New Alternator - Strange Problem
Old Feb 9, 2003 | 09:07 PM
_superduty_'s Avatar
_superduty_
Question New Alternator - Strange Problem
I have a 1990 Bronco with a 351W and AOD. I recently had a 3G 130amp alternator installed. Since then I am having a strange problem. When ever the truck is running and I shift into reverse the rpms drop and either fluctuate like it's trying to find the correct idle or the truck dies. This happens no matter if i shift into reverse from Park, Neutral or Drive. As soon as I feel the transmission engage it occurs. Vaccum leak maybe?. What would replacing the alternator have to do with this? Thanks for any suggestions.
Old Feb 10, 2003 | 08:23 AM
speed1972's Avatar
speed1972
I have done this conversion on my mustang. Did you use a new cable from the alternator to the battery? This is an absolute must...let me know, i'll help out, Larry
Old Feb 10, 2003 | 06:02 PM
_superduty_
The guy at the alternator shop said it wasn't necessary to replace the cable. I am still not clear as to what this has to do with the engine dying when I shift into reverse. Have you had this problem?
Old Feb 10, 2003 | 11:22 PM
speed1972's Avatar
speed1972
It really is necessary.. it puts more of a load on the system than it can handle with the stock wiring... you need a heavier guage wire to run to the battery. I know from experience, I fried an alternator and could have done some other damage electrical wise but I got lucky... so it is possible.. Did the problem start right after you put the alternator on? Does it only do it in reverse? I will get a link for you to read
Old Feb 11, 2003 | 06:24 PM
_superduty_
Yes it started up only after the alternator was installed. It only happens when I shift into reverse and then only after i feel that little lurch when the transmission engages in reverse. It doesn't matter if I shift from Park, Neutral or Drive into Reverse, the rpms drop, fluctuate and most of the time the engine dies.
Old Feb 11, 2003 | 06:33 PM
steve83's Avatar
steve83
The alternator never puts out more than the truck needs, so the stock cable is fine until you put more load on it than the stock cable can handle, which is probably 140A. I've been using a 130A alternator for 4 years with the stock wire and a 9000lb winch with no problems.
The most likely cause of the engine dying is the IAC, so pull the codes.
Old Feb 11, 2003 | 08:47 PM
_superduty_
Thanks Steve. I will pull the codes this weekend. I am wondering though why it only dies when I put it in reverse and not drive?
Old Feb 11, 2003 | 09:36 PM
speed1972's Avatar
speed1972
oh your right, it started after he changed alternators but that doesn't have anything to do with it.... read this when you get the chance.. its on a mustang but same principle
3g alt upgrade
Old Feb 11, 2003 | 09:45 PM
Bob Ayers's Avatar
Bob Ayers
The motor torques in a different direction in reverse. I would say
you have a maginal contact at an electrical connector that is
getting stressed when the motor torques in reverse..
Old Feb 12, 2003 | 03:56 PM
Kemicalburns's Avatar
Kemicalburns
What is your idle speed at when your shifting into reverse. The line pressure goes up when shifting into reverse and if your idle is to low then it can cause your motor to die. When was the last time the tranny was serviced. might be something to consider to.
later
Old Feb 16, 2003 | 01:26 PM
speed1972's Avatar
speed1972
what ever happened? did you get it figured out?
