4x4 switch?
Old Jan 20, 2009 | 11:49 AM
einsteindog's Avatar
einsteindog
4x4 switch?
went to put my truck into 4 wheel drive. Push the button. All was well,the light went on next to the button and on the dash. After ten minutes, the lights went off.if you tap the button the light will flicker.I replaced the transfer motor last year. could the switch be bad? I hear a clicking under the dash.
Old Jan 20, 2009 | 01:47 PM
Virto's Avatar
Virto
The clicking is probably a relay. I know the wiring to the motor on the transfer case is a common failure point. If you don't hear the case engaging when you push the button, I'd start down there.
Old Jan 21, 2009 | 07:40 AM
einsteindog
is the relay located in the dash on the passenger side? Thats where the clicking is coming from.
Old Jan 21, 2009 | 10:05 AM
einsteindog
Does anyone know where to get a new 4x4 switch located on the dash
Old Jan 21, 2009 | 10:52 AM
Virto's Avatar
Virto
Uh oh, did the switch break or suffer at the hands of an unhappy owner?
I'd check with FTEPartsguy.
Old Jan 21, 2009 | 12:05 PM
einsteindog
I'm not sure it is the dash switch. The low range button works fine. The 4x4 button doesn't work at all. just hearing a click under dash.
Old Jan 22, 2009 | 02:33 PM
einsteindog
any help out there? Go to engage the 4 wheel drive, only hear a clicking on passenger side. checked the module the red LED light stays on. theres no dash light for 4x4. Have no low range either. Replaced the motor last year. Any ideas?
Old Jan 22, 2009 | 02:51 PM
alxsnmr's Avatar
alxsnmr
There is a reset button on the module, a white one if I remember right that you press and it will reset. It usually Flashes when it has a fault in the system. If it doesnt then you may have to check the transfer case motor and wiring to make sure a broken wire or corrosion hasnt happened to the wiring and or harness.
You can go to broncograveyard.com and get the dash switch as well.
whale15
1983 - 2012 Ranger & B-Series
Aug 7, 2015 10:09 AM
garagegods
Jul 5, 2015 08:16 PM
georgeda
Escape & Escape Hybrid
May 20, 2015 07:19 PM
CraigK
21
Jun 17, 2010 02:09 PM
zmanmike
Apr 14, 2005 09:51 AM
