under dash pedals on ebay
Old Feb 28, 2013 | 06:44 PM
dynamic's Avatar
dynamic
anybody running this setup?
anyone see a setup with a clutch pedal?
1 Day Sale 1953 54 55 1956 Ford Truck Firewall Brake Booster Master Pedal Kit | eBay
Old Feb 28, 2013 | 06:52 PM
AXracer's Avatar
AXracer
I modified a pedal set from a 92 Camaro Had to move the clutch and brake pedals apart so they straddled the steering column. I chose that donor since I was using a T56 out of the same donor and wanted to use the OEM clutch MC to match the slave. I replaced the Camaro brake booster with a SS 7" dual diaphram one.
Old Feb 28, 2013 | 07:28 PM
Rusted56's Avatar
Rusted56
I've researched a bit, and found a couple of suppliers, but their stuff isn't cheap......
I personally like the one from Kugel Components, link here.
Kugel Komponents, Quality Komponents Since 1969
Willwood also has them, but I didn`t like how they mount as much as I like the Kugel one. I`m not much for E-bay, so you may find this stuff cheaper there....
I will likely order the Kugel bracket alone, and get the master cylinder, cluch master and booster locally, as I`ve had some problems in years
gone by with new and rebuilt master cylinders, and I know that my local parts guys will take care of me if I have any problems. I`ll likely get the
parts cheaper locally as well...
Old Feb 28, 2013 | 07:58 PM
bigwin56f100's Avatar
bigwin56f100
I would think that 57-60 ford truck pedal assembly would be the easiest to modify to fit as they are a hanging design and they use the same type of steering column. And if you are going Hydraulic clutch even better as thats what they were in 57-60
xjzero
May 15, 2019 06:49 PM
Vette1976
May 25, 2017 10:35 PM
newguy399
15
Jul 26, 2015 08:03 AM
BigJim99
Feb 7, 2008 07:41 AM
blueovalboy86
Jan 29, 2008 07:46 PM
