Help with EOT sensor
Old Feb 28, 2013 | 05:37 PM
hoytfan99's Avatar
hoytfan99
After sitting 24hrs or longer my eot is 16-17 degrees higher than others so I replaced the eot sensor right behind the oil filter, didnt change anything is their something I'm missing like another sensor?
Old Feb 28, 2013 | 06:03 PM
69cj's Avatar
69cj
By others are you referring to the ect. Maybe that's the problem. How do they compare to ambient?
Old Feb 28, 2013 | 06:11 PM
VQT's Avatar
VQT
Swap the coolant temp sensor and oil temp sensor to check the temp. spread again after more than 12 hrs.
Old Feb 28, 2013 | 07:15 PM
dannyboy950's Avatar
dannyboy950
When you replaced the sensor was it a single wire sensor or a multi wire sensor? The single wire is the dash gauge sensor.
Old Feb 28, 2013 | 07:47 PM
MC5C's Avatar
MC5C
The temp sensor is at 10:00 sort of beside the oil filter while the pressure switch is at 11:00, more behind it.
MelvilArnt
13
Nov 2, 2016 02:27 PM
Vertical Escape
Feb 20, 2008 10:19 PM
dsheleg
Feb 17, 2005 09:20 PM
scrimbaby
Electrical Systems/Wiring
Sep 19, 2004 07:45 PM
smittyranger1993
1983 - 2012 Ranger & B-Series
May 5, 2004 09:39 PM
