0299 code
Old Feb 28, 2013 | 04:17 PM
whlman39's Avatar
whlman39
0299 code
You guys are probably getting aggravated with me but, had my cousin run scan, came up with 0299 code vgt. I did some reading on here, is it possible for overboost that would expand and pop the cac tube, thats what I just replaced, but still no pwer,black smoke. I have read before on here about vanes need cleaning? is there a tutorial on here for that if so. Thanks
Old Feb 28, 2013 | 04:53 PM
mustang_309's Avatar
mustang_309
Heres a youtube video of cleaning the turbo.
Old Feb 28, 2013 | 05:06 PM
whlman39's Avatar
whlman39
Thanks Mustang
Ill check it out,at wits end.
Old Feb 28, 2013 | 05:12 PM
mustang_309
I would take more time and clean it better than the guy in the video, at least it gives you a good overview of what needs to be done.
Old Feb 28, 2013 | 05:14 PM
69cj's Avatar
69cj
Keep in mind P0299 can be over or under boost however, if you popped a cac hose it's probably over boost.
Old Feb 28, 2013 | 05:24 PM
whlman39's Avatar
whlman39
Thanks
Yah probably over boost is why i hear air looking for a place to go when i rev it.But its not getting to intake or i wouldnt have black smoke??????
Old Mar 2, 2013 | 06:41 AM
mustang_309
It is possible they were sticking in the closed position initially and now are stuck in the open position.
Old Mar 2, 2013 | 07:32 AM
CPB1's Avatar
CPB1
I have from my notes: P0299 EP Turbo/Super Charger Underboost EP sensor, VGT control valve slow/lack of response
Old Mar 2, 2013 | 03:06 PM
whlman39's Avatar
whlman39
At wits end!!
Pulled turbo this morning for p0299 code, didnt find really anything,cleaned everything re installed. No Good. Same no power very little boost on gauge. I guess Ill back up is there something internally that can go wrong with cooler. All i know is when you rev it and let off it sounds like a tornado internally coming from outlet side of cooler. The bright side is even my 11 year old can pull the turbo. Lol
Old Mar 2, 2013 | 06:08 PM
CPB1's Avatar
CPB1
You can try cleaning the EBP sensor. It's on the driver side on top of the tube coming from the exhaust manifold.
Old Mar 2, 2013 | 06:27 PM
whlman39's Avatar
whlman39
EBP?
Would that have caused the sudden overboost?
Old Mar 2, 2013 | 06:47 PM
CPB1's Avatar
CPB1
Not sure about that, sorry. I know EBP effects turbo operation. I think a plugged EBP sensor causes underboost,or no boost.
I think the key parameters that control boost are EBP and BARO.
I am not sure why you would have sudden overboost.
Old Mar 3, 2013 | 09:44 PM
whlman39's Avatar
whlman39
No luck!!
Did turbo vanes,checked intercooler, ebt sensor.Could the howling air i hear by cooler be caused from an exhaust restriction??? Runs and sounds fine till you rev and let off, sounds like a tornado under hood. Not leaking air but trapped air if that makes any sense, 4" exhaust no cat. Thanks
Old Mar 3, 2013 | 09:53 PM
m-chan68's Avatar
m-chan68
Enough farting around already. Is there any way you can upload and post a video of the noise you speak of. Have an assistant rev up the engine in PARK or NEUTRAL while you video exactly where the source of this air noise originates, so that we can give you better answers.
Old Mar 4, 2013 | 11:50 AM
whlman39's Avatar
whlman39
youtube upload
uploaded a vid on youtube Ford 6.0 howling air sound. Couldnt get it to link here?
