0299 code
Old Mar 5, 2013 | 08:43 PM
  #46
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Conversion will put him at around 14.8. Since the scanner he used did not add a decimal to the figures, and one was 15, I would say it was close enough to being good.
Old Mar 5, 2013 | 08:44 PM
  #47
BLADE35's Avatar
BLADE35
Originally Posted by whlman39
Ok just went and took for short ride, with ebp un plugged, it was relatively cold since i did readings,seemmed a liitle more responsive and i did achieve close to 20 psi boost, but still extremely loagy and the horror film roar of air is still there.LOL
I dont really know how to take this^^
Did it get any better????
It will always Turbo Fart if the Engine is reved up or under High Load and the Axcelrater pedal is suddenly let off
How much Boost did you get Before???? you unplugged the EBP sensor???
Old Mar 5, 2013 | 08:45 PM
  #48
BLADE35's Avatar
BLADE35
Cool thanks for doing that Sean
One day you will have to teach me how to convert it LOL
Id say BARO is Good
Old Mar 5, 2013 | 08:52 PM
  #49
whlman39's Avatar
whlman39
yes seemed a little better. I guess to better decribe if you stuff your foot in it, its a 4 cylinder trying to pull a semi semi truck. did notice more boost to almost 20,before maybe 5 or so. Still never heard that sound till till other day.
Old Mar 5, 2013 | 08:54 PM
  #50
BLADE35's Avatar
BLADE35
Ok ran a scan for values
KOEO
BARO 30.1
MAP 14
EBP 15
IDLE
BARO 30.1
MAP 15
EBP 18
2500 RPM
BARO 30.1
MAP 20
EBP 52
Also ran another scan still 0299 and P0478 P2263. Thanks guys.
For the Sake of the Thread
<table style="width: 681pt; border-collapse: collapse;" border="0" cellSpacing="0" cellPadding="0" width="908"><colgroup><col style="width: 77pt; mso-width-source: userset; mso-width-alt: 3730;" width="102"><col style="width: 86pt; mso-width-source: userset; mso-width-alt: 4205;" width="115"><col style="width: 237pt; mso-width-source: userset; mso-width-alt: 11556;" width="316"><col style="width: 281pt; mso-width-source: userset; mso-width-alt: 13714;" width="375"><tbody><tr style="height: 12.75pt;" height="17"><td style="border: 0.5pt solid black; width: 77pt; height: 12.75pt; background-color: transparent;" class="xl66" height="17" width="102">P0299</td><td style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: black black black windowtext; width: 86pt; background-color: transparent;" class="xl66" width="115">EP</td><td style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: black black black windowtext; width: 237pt; background-color: transparent;" class="xl65" width="316">Turbo/Super Charger Underboost</td><td style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: black black black windowtext; width: 281pt; background-color: transparent;" class="xl65" width="375">EP sensor, VGT control valve slow/lack of response</td></tr></tbody></table>
<table style="width: 681pt; border-collapse: collapse;" border="0" cellSpacing="0" cellPadding="0" width="908"><colgroup><col style="width: 77pt; mso-width-source: userset; mso-width-alt: 3730;" width="102"><col style="width: 86pt; mso-width-source: userset; mso-width-alt: 4205;" width="115"><col style="width: 237pt; mso-width-source: userset; mso-width-alt: 11556;" width="316"><col style="width: 281pt; mso-width-source: userset; mso-width-alt: 13714;" width="375"><tbody><tr style="height: 12.75pt;" height="17"><td style="border: 0.5pt solid black; width: 77pt; height: 12.75pt; background-color: transparent;" class="xl66" height="17" width="102">P0478</td><td style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: black black black windowtext; width: 86pt; background-color: transparent;" class="xl66" width="115">EP</td><td style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: black black black windowtext; width: 237pt; background-color: transparent;" class="xl65" width="316">Exhaust Pressure Control Valve High Input</td><td style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: black black black windowtext; width: 281pt; background-color: transparent;" class="xl65" width="375">EP sensor, VGT control valve slow/lack of response</td></tr></tbody></table>
<table style="width: 681pt; border-collapse: collapse;" border="0" cellSpacing="0" cellPadding="0" width="908"><colgroup><col style="width: 77pt; mso-width-source: userset; mso-width-alt: 3730;" width="102"><col style="width: 86pt; mso-width-source: userset; mso-width-alt: 4205;" width="115"><col style="width: 237pt; mso-width-source: userset; mso-width-alt: 11556;" width="316"><col style="width: 281pt; mso-width-source: userset; mso-width-alt: 13714;" width="375"><tbody><tr style="height: 25.5pt;" height="34"><td style="border: 0.5pt solid black; width: 77pt; height: 25.5pt; background-color: transparent;" class="xl66" height="34" width="102">P2263</td><td style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: black black black windowtext; width: 86pt; background-color: transparent;" class="xl66" width="115">MAP</td><td style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: black black black windowtext; width: 237pt; background-color: transparent;" class="xl65" width="316">Turbo/Super Charger System Performance</td><td style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: black black black windowtext; width: 281pt; background-color: transparent;" class="xl65" width="375">CAC system leaks, MAP hose disconnected, exhaust system leaks, intake system leaks</td></tr></tbody></table>
Old Mar 5, 2013 | 08:56 PM
  #51
BLADE35's Avatar
BLADE35
I guess you could undo the downpipe clamp to vent the Exhaust to see if its plugged
I doubt it plugged but this would Rule it Out
Who knows you might be the #2 guy with plugged exhaust LOL
Old Mar 5, 2013 | 09:04 PM
  #52
whlman39's Avatar
whlman39
I can do that tomm, i bought the truck with 4" exhaust and cat gone, so I can only assume muffler is an upgrade too as you say high flow. I appreciate all your guys help thus far. Ill update in morning.
Old Mar 5, 2013 | 09:16 PM
  #53
amdriven2liv
Id say BARO is Good
Google is your friend!!!
I know nothing!!! And it will only take me a moment to teach that to you!!!
Old Mar 5, 2013 | 09:40 PM
  #54
mustang_309's Avatar
mustang_309
29.92 inches of mercury ( hg ) = 14.7 PSI or 1 atmosphere
Old Mar 6, 2013 | 11:08 AM
  #55
whlman39's Avatar
whlman39
I unhooked down pipe from back of turbo this morning,hard to really seperate it that far,so Im sure still had a fair amount of exhaust going down tailpipe. I took for ride,didnt seem any better. Still had ebp unplugged,should i have plugged that back in? Idk im thourohly confused as from a stop and go on the highway it went from alive to dead. Ill throw something out there, just my thought. I have been struggling for 20,000 miles with poor performance up until you guys mentioned the hpop. Replaced and it was great. Is it possible all of that unburnt fuel has partially plugged muffler?? I see no markings on the muffler, so i'm only assuming that when cat was taken off it was replaced.
Old Mar 6, 2013 | 01:57 PM
  #56
whlman39's Avatar
whlman39
I did some reading of past posts, black smoke no power. Hypothetically speaking: the underboost would not give motor enough air to burn fuel? Turbo was cleaned and pulled dust cover and pulled actuator back and forth and verified vanes opened and closed as video showed. I assume vanes open to make boost? Is it possible solenoid that opens and closes them is bad? I unplugged it ,no change in motor sound and revved up no difference? Shouldnt there be some sort of difference
Old Mar 6, 2013 | 03:09 PM
  #57
m-chan68's Avatar
m-chan68
Yes there definitely should be a noticeable difference when the VGT actuator is plugged in or not. If you have access to a wiring pigtail, (exactly identical to that of a 7.3L injector or IPR connector), you can test this out yourself, by holding it up to 1200 RPMs in PARK or NEUTRAL and supplying your own power and ground directly to the actuator via a pigtail connector. When you do this, you should hear the turbo spool up almost immediately, and stop when you remove the power and ground supply. If it does not, the VGT actuator is bad. By doing this, you elimate the need to get your hands on a scan tool to take active command of the actuator.
Old Mar 6, 2013 | 03:22 PM
  #58
whlman39's Avatar
whlman39
Cool. My cousin has done alot of work on 7.3 I'll see if hes got one and try it. Is that something that can just go bad? Is there another way to test if i cant get a pigtail. I can have him scan again, i assume there is vgt values that should change, Just takes me a day to track him down.
Old Mar 6, 2013 | 06:37 PM
  #59
BLADE35's Avatar
BLADE35
lOOKS like Mike got you covered
here some more info
TURBO VGT DIAGNOSTIC
http://www.forddoctorsdts.com/techni...sorBooklet.pdf
Old Mar 7, 2013 | 03:21 PM
  #60
whlman39's Avatar
whlman39
here some more info
Going to do test that Mike mentioned here shortly. ??? If actuator is bad, anything i need to know to remove and reasonable place to purchase new or go to Ford??? Do they sell new pigtails as mine has a broken locking tab. Thanks
