Decode my vin
Old Feb 28, 2013 | 04:05 PM
Chris Guthro's Avatar
Chris Guthro
Decode my vin
F15JCA78824. Theres the vin of a truck a fellas willing too give me. Hes a coupoe hours away and i knew him from a guy at work. He knew nothing about it. Before i go pick it up can anyone tell me anythig about it?
Old Feb 28, 2013 | 04:22 PM
mikeo0o0o0's Avatar
mikeo0o0o0
F15JCA78824
F15=F150 2WD pick up
J=460 cid 4bbl V8
C= Ontario Truck Plant
A78824=1976 model year consecutive serial number
Old Feb 28, 2013 | 05:41 PM
Chris Guthro
so it would be a c6? anyhing about maybe the rear end ratio in there? because its gonna be a drivetrain swap to my 84 f150..how much power would a 77, 460 4bbl have?
Old Feb 28, 2013 | 06:29 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Yeah, it's going to be a C6. Nothing on the rear is in the VIN, for that you'll need the "AXLE" code on the warranty plate that's on the drivers door. Not sure about the HP rating either. '77 ? The s/n on the VIN says it's a '76.
Old Feb 28, 2013 | 07:39 PM
Chris Guthro
Okay, the guy thought it was a 77 but must be a 76. He sent me this series of numbers too that i dont know what they mean either. Can anyone tell me ?? 133F F150 CU4 G15 06050 1976 E6
Old Feb 28, 2013 | 08:13 PM
xkpsanit's Avatar
xkpsanit
Those are the warranty plate #'s without the plate. Wait one....
Old Feb 28, 2013 | 08:18 PM
Chris Guthro
Can they reveal any information?
Old Feb 28, 2013 | 08:23 PM
xkpsanit's Avatar
xkpsanit
Im trying to figure out which ne is your axle code, yet. I think its g15. But that format, doesnt match the 79 reference i was using. Wait one again
Old Feb 28, 2013 | 08:24 PM
xkpsanit's Avatar
xkpsanit
It is a 133 inch half ton built in 1976
Old Feb 28, 2013 | 08:32 PM
xkpsanit's Avatar
xkpsanit
Gvw 6050# thats about all I can get u from my Android, i believe there is a body config, axle code and assembly plant in there too. IIRC. Mike will be able to decode the complete thing
Old Feb 28, 2013 | 08:35 PM
Chris Guthro
One i found online it seemed to say its a 3.25 9 inch
Old Feb 28, 2013 | 08:36 PM
xkpsanit's Avatar
xkpsanit
Was that for a 76 ?
Old Feb 28, 2013 | 08:38 PM
Chris Guthro
I thought it said 73-79
Old Feb 28, 2013 | 08:46 PM
xkpsanit's Avatar
xkpsanit
That is a 9 inch ratio, seems a little low for a big block.... hmm. i believe the CU4 is the body config , but i dont remember what the E6 means. This is from memory. Maybe google can help from here. We'll get this before Mike logs back in
Old Feb 28, 2013 | 08:55 PM
mikeo0o0o0's Avatar
mikeo0o0o0
133 F F150 CU4 G 15
06150 1976 E6
WB 133= 133" wheelbase (longbed)
Color F= Dark Ginger Metallic
Model F150=F150 2WD pickup 6050 GVW
Body CU4= (CU) Tan vinyl and Tan cloth Ranger XLT (4) Styleside bed
Trans G= Automatic transmission
Axle 15= Ford 9" non-locking 3.25 3750 lb capacity
GVW 06150= 6150 lb GVW (I think this should actually be 06050)
1976=1976 model year
DSO E6= That DSO code doesn't exist. If it was B6 that would be the western district of Canada. American DSO's (District Sales Office) are two digit numbers.
Also, it looks like your truck has manual steering, if it's equipped with power steering there should be a "J" after the axle code (15J)
