speedometer needle jumping
Old Jun 1, 2003 | 04:33 AM
trueblue_79's Avatar
trueblue_79
Question speedometer needle jumping
my sppedometer needle will jump lets say if im going 25 it will go like....20....25....35....25.... and just kind of keep jumping to thos eposeeds bakc and forth. it started after i had pulled my buddies chevy he got stuck in the local dunes out. any idea what is causing this and how to fix it? is it a losse/stretched speedometer cable? thanks!
Old Jun 1, 2003 | 08:36 AM
94van's Avatar
94van
A jumping speedometer usually indicates the need for lubricating, or a kink in the housing. Check for kinks, if none, pull the inner cable out, clean it, and lube with white grease, or something that won't get stiff in cold weather. Don't over-grease, just a heavy film of grease will do.
Old Jun 1, 2003 | 09:52 AM
ecarter50's Avatar
ecarter50
On 92-later there is no cable the speedometer is electronic. Check the speed sensor in the rear axle housing.
Old Jun 1, 2003 | 11:15 AM
MustangGT221's Avatar
MustangGT221
There are many threads on this, but here is one that should spell everything out for you.
https://www.ford-trucks.com/dcforum/...ID39/3562.html
Old Jun 1, 2003 | 11:25 PM
steve83's Avatar
steve83
Here's another one: https://www.ford-trucks.com/forums/s...hreadid=104045
scootro5.0
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Apr 23, 2014 09:16 PM
Hughesjr84
Feb 7, 2014 08:13 PM
hav24wheel
56
Mar 27, 2012 11:29 AM
mdr617
Aug 1, 2011 05:05 PM
live for the rush
1983 - 2012 Ranger & B-Series
Aug 9, 2004 06:01 PM
