Speedometer jumping???
Old Aug 1, 2011 | 08:00 AM
mdr617's Avatar
mdr617
So the truck is a 79 f100, 351m, c-6 auto, 2wd, and i have had this problem before, but it "went away" for a while, but now its back. The speedometer works fine untill about 40-60mph, then the needle starts jumping around, sometimes it goes up to 75-85mph, when i know im going a lot slower. But the needle moves randomly and floats between 40-85, as doesnt do it all the time.... What do you guys think it could be? Anyone else have this problem?
Old Aug 1, 2011 | 08:06 AM
Aussie_F_trucker's Avatar
Aussie_F_trucker
Mine does that too, the outer sheath of the speedometer cable was melting on the headers and causes the inner cable to bind up.
Hope that helps
Old Aug 1, 2011 | 09:59 AM
co425's Avatar
co425
Yep. Bad or dry cable. Or wrong cable not inserted into spedo fully.
Old Aug 1, 2011 | 11:34 AM
78 PEB's Avatar
78 PEB
I'd try lubing it with some speedo cable lube. Basically a liquid graphite. That may be all the problem is.
Old Aug 1, 2011 | 04:16 PM
Rambo76's Avatar
Rambo76
I believe someone once told me to try white lithium grease. I Never got around to it though.
Old Aug 1, 2011 | 05:05 PM
buckin69bronco's Avatar
buckin69bronco
I had a similar problem with my early bronco, turned out to be a worn out bushing on the speedo that was letting the metal tabs that rotate around the magnet lightly touch the magnet. You might want to make sure the cable isn't pulling down on the speedo to cause a misalignment and you may want to check the alignment of the spinning tabs and the magnet inside the speedo. To fix mine I slightly bent the tabs outward till they didn’t hit. This may have an effect on the accuracy of the speedo by a few mph but it didn't bounce around anymore.
RadioControlGuy85
Dec 12, 2012 04:55 PM
72sportcustom3906.4l
Jun 20, 2009 05:56 AM
WhiteBroncoII2WD
Bronco II
Oct 24, 2008 11:20 AM
MemOrex
General Automotive Discussion
Oct 3, 2005 03:49 PM
