First post - newbie question
Old Feb 26, 2013 | 09:46 AM
Rick993's Avatar
Rick993
Hello,I have a 93 f-250 4x4 bone stock. Looking to upgrade a bit after 155k miles. I'm looking at the Dynomax 19430 sys. It indicates 2.5" at the intake manifold take off to 4" after muffler. My question is; what is the stock diameter start to end?
Thx in advance
Rick
Old Feb 26, 2013 | 09:56 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Can we have a little more info? I have no idea what youre talking about
Old Feb 26, 2013 | 10:56 AM
bashby's Avatar
bashby
I believe he wants to know the diamater of each part of the stock exhaust system. Engine size matters, which is not indicated. The easiest thing to do would be measure what you have, I doubt anyone knows off the top of their head.
Old Feb 26, 2013 | 11:21 AM
bashby's Avatar
bashby
Just realized this is the idi section, so you must have a 7.3. Someone might be able to tell you diameters. The Y pipe is a big restriction, so if the system you are looking at doesnt replace that, you might need to fabricate a Y to get the full benefit.
Old Feb 26, 2013 | 11:45 AM
Rick993's Avatar
Rick993
Sorry,
1993 Ford F-250 4x4 super Cab 7.3 liter IDI diesel non turbo, E4OD transmission with 155,000 miles. My understanding is that some small gains in performance can be made by making engine intake and exhaust improvements. With respect to the exhaust improvements, the Dynomax exhaust system indicates that from the exhaust manifolds back, it starts at 2.5 inches and goes to 3 inches then 4 inches after the muffler, ending with a 5 inch tip at the end. My question was, what the initial diameter after the manifold was. If stock is also 2.5 inches, then replacing y pipe is not much use, and the Hyperdyne 3inch system (without y pipe) would be equivant?
Thank you in advance.
Old Feb 26, 2013 | 12:27 PM
hairyboxnoogle
Stock is 2 or 2.25, same size as the manifolds, but that would give you benefit. The stock Y was built for anything but power.. 4" is overkill for a NA engine, but if you plan to turbo later its a solid exhaust. Im looking at the Diamond Eye 4" turbo back dual exhaust myself.
Im not aware of any aftermarket exhaust kits for the IDI so make sure its not for 460 or 7.3psd or anything like that.
Old Feb 26, 2013 | 02:03 PM
Rick993's Avatar
Rick993
Thanks HBN
This is what I was looking at: it indicates Non Turbo only application
Dynomax Ultra Flo Welded Exhaust Systems 19430
Make:FORD
Model:F-250
Beginning Year:1988
Ending Year:1994
Engine Type:V8
Liter:7.3
CID:445
Engine Size:7.3L/445
Engine Family:International diesel V8
Application Notes:155 inch wheelbase non Turbo models only.
Truck Cab:Extended
Truck Bed Length:Long
Transmission:Automatic
Drivetrain:4WD
Doors:2-door
Old Feb 26, 2013 | 04:27 PM
bashby's Avatar
bashby
Thats the system, the y pipe looks pretty restrictive to me. Can,t remember exactly what stock looks like.
1986F150six
Jun 14, 2013 06:28 AM
A/Ox4
Jul 4, 2011 08:00 PM
85_Ford_6.9L_4x4
May 20, 2008 11:46 PM
penner857
Jan 19, 2007 03:14 AM
STX03F150
1997 - 2003 F150
May 9, 2005 09:56 AM
