Front end squeak
Old Feb 25, 2013 | 08:59 PM
davewave649's Avatar
davewave649
Front end squeak
So over the past few months my truck has developed a but of a squeak, it only happens on sharp bumps (potholes, cracks, crappy California roads in general) and its starting to drive me nuts. It seems to be coming from the passenger side either in the cab or farther forward. I have replaced the fender antisqueaks and I don't think it's anything in the door. I think te steering stabilizer is causing problems because I now have a pop in the front end so that will be pulled off ASAP and eliminate it as a potential culprit.
Any ideas on what it could be? Ill try to get video or audio of the squeak tomorrow.
Thanks
Old Feb 26, 2013 | 04:16 AM
Customcab's Avatar
Customcab
Does the front end lean more lower to the passenger side? Leafs could be getting weak as well.
Old Feb 26, 2013 | 04:38 AM
fordpt's Avatar
fordpt
Need to know what you are working on. Coil spring 2 wheel drive,leaf spring 2 wheel drive, 4 wheel drive. For now push down on front bumper ( bounce front end).
Old Feb 26, 2013 | 08:11 AM
63' f100's Avatar
63' f100
This probably sounds dumb, but you could stand on the bumper and bounce up and down and see if it squeaks.
Old Feb 26, 2013 | 09:46 AM
davewave649
F100 with a solid axle 2wd. No noticeable lean to passenger side. Ill see if I can get it to do it by bouncing it after class.
More ideas?
Old Feb 27, 2013 | 10:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Front/rear rubber spring and shackle bushings encased in metal. Rubber cracks, squeeks begin. Spray some soapy water on the bushings, see if squeek disappears.
When was the last time the front wheel bearings were repacked?
Old Feb 27, 2013 | 11:10 AM
davewave649
Bushings were replaced 2 years ago on the front, still need to do the rears. Bearings were packed when I did the disk brake swap 3 or so years ago. Ill try the soapy water and see if it helps
huntinglandscaper
Jun 4, 2018 09:44 PM
tim peterson
1997 - 2003 F150
Sep 12, 2011 04:06 AM
48super6
Oct 12, 2004 09:49 PM
ExpyBob
Feb 21, 2004 10:30 AM
ford528n
1978 - 1996 Big Bronco
Dec 7, 2002 12:24 AM
