Sponsored by: Auxito
Rebuilt engine
Old Feb 25, 2013 | 06:13 PM
dbreckman's Avatar
dbreckman
Rebuilt engine
I am looking to replace the engine (5.4) in my '99 F150 4X4. I have found a really good deal on a rebuilt, but I'm curious if there's a way to tell if the heads have been updated to correct the spark plug blow out issue.
Old Feb 26, 2013 | 09:01 AM
KhanTyranitar's Avatar
KhanTyranitar
Depends on who you get it from. In my experience, all off the shelf rebuilt engines are what I call budget rebuilds. They often do not update parts, they usually only fix what cause the motor to fail int he first place and maybe a seal kit. What prohibits you from having your old engine rebuilt? A proper rebuild is usually better than a new engine.
If your rebuilt motor comes from a smaller private firm instead of a national rebuilder, the chances that it is good are better. But even so, it really depends on who did the build. As you say its a good deal. That tends to imply that corners were cut.
Trazkiru
1997 - 2003 F150
Jul 14, 2017 07:05 AM
jnldr
26
May 22, 2010 09:08 AM
topfisherman
1978 - 1996 Big Bronco
Mar 5, 2004 10:19 PM
CRJ900
Jan 17, 2002 08:22 AM
CRJ900
13
Jan 16, 2002 02:29 PM
