Winter Hell
Old Feb 25, 2013 | 01:43 AM
thebutcherbunny's Avatar
thebutcherbunny
Winter Hell
Hey everyone, I'm new to the site, but joined for a good reason. I have a '93 F150 5.0 with dual tanks. Recently, in lower temperatures. I've been having some troubles with it starting, staying idle and taking fuel. I've replaced the fuel pressure regulator and it ran great. then the temperature dropped tonight and it went back to stalling and acting thirsty for gasoline. I let it warm up for about a good 20 minutes and the thing will run like it's new. Anything before that, the second I put it into gear it will die, I'll have to hold my foot on the gas and wait to get her running again, then let her warm up until she's ready.
I'm not mechanically inclined however, I've been in parts for sometime not and here are my thoughts as to what it could be from doing a little research.
Fuel filter was changed about 5k miles ago. But possibly a bad fuel filter.
EGR Valve
Fuel Pump. Though the fuel pump sounds as if it's working normal as always.
I'm kind of lost here and nothing seems like it's going to be a cheap fix. So the real question is, what can I do to limp it through until my next payday?
Old Feb 25, 2013 | 01:48 AM
BigBlockF350's Avatar
BigBlockF350
Well, many vehicles tend to run better when they're warmed up. As far as the dying unless you're on the gas, what RPM does it idle at in gear when it's cold? You could always just tighten up your throttle linkage to crank it up 100-200 rpms at idle. It'll be less likely to stall, and it'll warm up quicker. That's IS a cheap fix.
Old Feb 25, 2013 | 02:04 AM
Intimnasc's Avatar
Intimnasc
First and formost welcome to the site and stick around a while theres a very good folllowing here.
Now the problem, Make sure your gas tank vents and the vacuum canisters at the front are getting good vacuum. Follow your vapor lines out and make sure nothing is obviously crushed or clogged. Rather than a workaround I would seek the problem. Get an OBDI scan tool from someone and check it for codes. Theres a way to do it with a paper clip too but the tool is like 25 dollars at Oreilly and comes with instructions.
Old Feb 25, 2013 | 02:49 AM
thebutcherbunny
I honestly have no idea, I don't have a gauge that reads the RPM, which I wish I did because it would help me better pin point the problem. Again, I'm not the least bit mechanically inclined, but I'm trying my damnedest to make sure it works. I will however look into it and see if it will work.
Old Feb 25, 2013 | 03:00 AM
lv2race's Avatar
lv2race
There's a couple of things you could try before you spend money on parts. First, disconnect your MAP sensor plug to see if it runs better. It won't last long as the computer will eventually try to compensate. If it runs better when the plug is disconnected, you probably need a new one. Remove and clean the IAC. But you really need to check for codes.
Old Feb 25, 2013 | 09:06 AM
timbersteel's Avatar
timbersteel
As stated by lv2race, disconnect IAC. Remove bllts attaching it to TB. Clean the plunger and bore using either electronic, brake cleaner or carb cleaner. Do not allow any chemical into solenoid/electrical part of sensor. Check gasket. If bad, replace. Reinstall. Disconnect neg. battery terminal at least 10 mins. Reconnect, then drive minimum of 5 miles @ 55 mph. You can also also let it idle for min of 10-15 mins as this will let it relearn idle. Check resistance values of ECT and ACT sensors when cold and when hot. Could be some discrepancies between the 2 sensors when cold. Rent, borrow, purchase fuel pressure tester to verify fuel pressure.
Also, do not tamper with TB plate screw. This is calibrated to your setup and adjusting it will only cause you more headaches in the future. If you wish to do so, attain the current TPS voltage its is providing with ignition switch on. This will give you a close value if you ever need to adjust TB plate screw.
Old Feb 25, 2013 | 09:16 AM
jroehl's Avatar
jroehl
This thread is useless without codes. The rest is throwing darts blindfolded.
Jason
Old Feb 25, 2013 | 09:22 AM
timbersteel
Agreed on codes. I thought I posted that but guess it got deleted when my phone refreshed when i started that reply.
Old Feb 25, 2013 | 12:36 PM
thebutcherbunny
I'll definitely be getting my codes today.
Papasmithnc
1997 - 2003 F150
Sep 9, 2014 10:37 AM
crazy_urn
22
May 27, 2014 12:47 PM
dilbone56
13
Mar 18, 2009 04:42 PM
FoxyPaws
Aerostar
Mar 19, 2004 04:49 PM
Quadiquizm
Nov 30, 2002 01:03 PM
