batteries seem to still be up i dont have a voltage meter to find out i have replaced it with others to see if it would stop and it just jeeps doing it i ordered a new cod reader after you and i got talking about that yesterday got a auto enginuity a little pricey but atleast it will work ill see what it is a soon as i get it its suposed to be here the 5th so ill update you soon as i get the tool on the truck
well i went out to go start it and relay number 2 and that is the IDM relay is clicking and is giving me a CEL and the clicking as soon as i turn the key
Put a load on the batteries such as turning the lights ON when the IDM relay is clicking and see it it stops.
Well you guys are sure to like this I went out and charged the (batteries and put a load on the truck by turning on the lights to see if the load would stop the clicking like the other person suggested And it was like the starter was trying to engage its like the truck is on the fritz has anyone ever seen this before or am I like the only person with at retarded truck.
Your ABS Light is flashing a problem code. The number of flashes id the code number. However it should not be in the test mode unless you disconnected the test lead and grounded it.
