HELP
Old Feb 27, 2013 | 01:17 PM
  #31
rowbaird's Avatar
rowbaird
found it and unplugged the heater and its still clicking at the relay
Old Feb 27, 2013 | 02:23 PM
  #32
DIYMechanic's Avatar
DIYMechanic
Have you tried swapping that relay with another one? Are the batteries low on charge again? What is the system voltage when you turn the key on?
Old Feb 27, 2013 | 10:19 PM
  #33
rowbaird's Avatar
rowbaird
batteries seem to still be up i dont have a voltage meter to find out i have replaced it with others to see if it would stop and it just jeeps doing it i ordered a new cod reader after you and i got talking about that yesterday got a auto enginuity a little pricey but atleast it will work ill see what it is a soon as i get it its suposed to be here the 5th so ill update you soon as i get the tool on the truck
Old Feb 27, 2013 | 11:36 PM
  #34
ReBilld's Avatar
ReBilld
Take the IDM out and shake it. It may have water in it. It's a common problem with these trucks.
Old Feb 28, 2013 | 06:16 AM
  #35
rowbaird's Avatar
rowbaird
i would try that but i had allready taken it out and swapped it out with another one that i had had and it still is doing the same thing
Old Feb 28, 2013 | 09:23 AM
  #36
Hussler's Avatar
Hussler
Originally Posted by rowbaird
well i went out to go start it and relay number 2 and that is the IDM relay is clicking and is giving me a CEL and the clicking as soon as i turn the key
Put a load on the batteries such as turning the lights ON when the IDM relay is clicking and see it it stops.
Old Feb 28, 2013 | 05:04 PM
  #37
rowbaird's Avatar
rowbaird
Well you guys are sure to like this I went out and charged the (batteries and put a load on the truck by turning on the lights to see if the load would stop the clicking like the other person suggested And it was like the starter was trying to engage its like the truck is on the fritz has anyone ever seen this before or am I like the only person with at retarded truck.
Old Mar 1, 2013 | 06:30 AM
  #38
DIYMechanic
So when you charged the batteries and turned the headlights on the starter tried to crank without you turning the key?
Old Mar 1, 2013 | 08:53 AM
  #39
rowbaird's Avatar
rowbaird
Well the key was turned over to the run position where the wait to start light activates
Old Mar 1, 2013 | 09:12 AM
  #40
DIYMechanic
Try unhooking all the leads from the starter solenoid (careful-- at least one of them is energized).
Old Mar 4, 2013 | 04:29 PM
  #41
mkeith54's Avatar
mkeith54
Your ABS Light is flashing a problem code. The number of flashes id the code number. However it should not be in the test mode unless you disconnected the test lead and grounded it.
cornerstone86
Apr 1, 2016 03:59 PM
OrangeRanger
May 7, 2015 01:33 PM
dreo2003
15
Jan 20, 2008 11:14 PM
Bonesdc
Bronco II
Sep 25, 2003 11:54 AM
Billyboy501
Mar 3, 2003 08:07 PM
