Modular V10 (6.8l)
Engine knock
Old Feb 23, 2013 | 11:07 PM
Aune163rd's Avatar
Aune163rd
Engine knock
Hey guys, been a while since I got on here, V10 is running great. Up til recently its been fine, now it has this tick/knock throughout the power band. It mainly does it under 2500 RPM....I noticed its also starting to burn oil. i burn a quart every 3k miles. I am sure its not leaking. But its going somewhere.
It is driving me nuts cause its top end noise. Is it possible I got a pushrod or something going out, idk how these newer engines work very well. Is this engine a pushrod engine or does it run the rockers on cams?
Any advice would be great.
Specs:
2000 F-250 Triton V10
195,000k miles
4x4
Exhaust manifolds are in great shape.
Old Feb 25, 2013 | 11:33 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
It's overhead cam, so no pushrods.
If it were me, I'd do a compression check. Burning oil means either ring/piston/cylinder-wall issues, or it's running very rich in one or more cylinders and washing the oil off the cylinder walls - which will eventually cause ring/piston/cylinder-wall issues
If you go this route, as you pull the plugs, number them and keep them so you can tell which ones are rich/lean/cruddy/whatever.
Old Feb 25, 2013 | 12:06 PM
jh818's Avatar
jh818
Maybe check the torque on the spark plugs beforehand and see if it stops ticking. Some on here says it ticks prior to the spark plug spitting.
Old Feb 25, 2013 | 01:45 PM
krewat's Avatar
krewat
VERY good point
Also, make sure it's not the timing chains...
Old Feb 25, 2013 | 02:08 PM
jh818's Avatar
jh818
Originally Posted by Krewat
VERY good point
Thanks, Art.
Not sure about the oil burning, though. Some people here says 1 qt between oil changes is not unusual. I use Mobil synthetic and I usually have to top it off after 3k miles.
Old Feb 27, 2013 | 01:15 PM
Aune163rd's Avatar
Aune163rd
I'm running the Castro synthetic blend. I don't think its timing chain because it comes and goes. I also don't think its the spark plugs because it would have tossed it already. This started almost 10k miles ago...... it hasn't harmed the engine's power. I heard somewhere that the rocker arms can start ticking as higher miles mount up. Like I said it comes and goes. I like the comment of the oil consumption. What causes these engines to run rich?? MAF sensor? Does this have a IAC valve? What sensors would cause it to run rich ? Is it possible its injectors?
Old Apr 27, 2013 | 07:24 AM
samsdad02's Avatar
samsdad02
any resolution to this problem?
Old May 15, 2013 | 10:43 PM
cole1996's Avatar
cole1996
Specs:
195,000k miles
4x4
^^^^ This is almost word for word my truck!!!
Exhaust manifolds are perfect, new plugs and coils.
5 OEM COP's, 5 Accel COP's
Tick sounds like one cylinder loudest under 2500rpm, but is also audible above 3500.
VERY good point
Suggested milage for replacement? Just hit 161,000 miles.
Came on suddenly awhile ago.
Thanks,
Cole
Old May 15, 2013 | 10:52 PM
Aune163rd's Avatar
Aune163rd
Well my thread is old....but its still true, I found that the oil level corrosponds to the ticking.... The ticking is gone if you rev the engine a little bit.
Old May 15, 2013 | 10:53 PM
Aune163rd's Avatar
Aune163rd
I still own my truck. The COPs, Boots, Plugs havent been changed in 49k miles.
erwatt
Aug 24, 2015 11:32 PM
Aune163rd
Modular V10 (6.8l)
Dec 12, 2012 10:43 AM
carprojects
Modular V10 (6.8l)
13
Dec 24, 2010 04:58 PM
carprojects
Dec 15, 2010 03:03 PM
willycat115
Modular V10 (6.8l)
Sep 3, 2010 11:05 PM
