Feedback carb 10btdc
https://www.ford-trucks.com/forums/9...on-help-2.html
Plus save me some money as I just bought my coil and ignition wires. $130 and cost of harness.
All I would need is distributor and GM module. Jimsrebel has been running this combo for years with no problems. Will do more reasearch.
Was out at the junk yard today but they closed at 4 and I pulled in at 3:55, so didn't actually get to go in. If you still want it, I'll head back out tomorrow and take a look. I'm good either way. Here are some good reads..... JIM
https://www.ford-trucks.com/forums/9...gnition-3.html
https://www.ford-trucks.com/forums/1...-anywhere.html
https://www.ford-trucks.com/forums/1...l#post10632947
Ive just purchased a new TFI coil and ign wires November. The wires where Ford and all had 1986 stamped on them I guess they did that years ago if they where not original they sure looked it. Bought a new coil for the same reason plus the fact the location told me this would be a problem to replace and got them to do it during certifacation of van. Even on the hoist it took the mechanic some time and sighed relief when done.
So would have to dump these new parts .. buy replacements and find and pay for a harness . Will have to buy the dizzy either way and a $20 module . So why wouldent I try this first ? Members here running this for years with no problems .. Biggest issue seems to be keeping module cool with a heatsink and thats not an issue.
Only fault Ive heard of was from this thread and not sure if I read it right..Is there a problem here or did I read it wrong . ?
The Ford (use Motorcaraft only) Duraspark II modules are very good because they have a spark retard function for easier starting when hot.
Is it possible the GM module could be a problem on hot starts. I probably read it wrong as Ive heard no complaints..from the little research Iv done.
Jim ..have read all your posts on the subject and was hoping you where still here, Im still using feedback as yourself and your posts helped me make my decission.
I think one post I read said you had all the parts for a complete ford conversion but assume you havent got around to it yet as your current setup is working fine..is that a fair statement.?
I like the picture of your setup ..how long have you been using this setup ? Must be 4 years ? Any problems at all ?
Not sure if you read all posts but this van is running great and if I get 15mpg this summer may not do a thing. But if I do will start a new thread and hope your still around.
Too all of you
What would we do without you .
When I got the van certified there where 6 mechanics in the shop..yes 6.
Not one knew what a feedback carb was. Was at Hotspots autoparts and asked 2 employees about the feedback..they never heard of it . So lets not even mention ignition system..the guy who installed my coil had never seen one like it .What would I have done without the members of this board..tell me. And from reading all the posts that I have I know Im not the only one that feels this way.. Cheers to all of you.
The spark retard is only 2 deg, not sure how much difference it really makes.
If you have slow cranking and kick back issues when the engine is HOT you could also just switch to the newer PMGR starter, it spins faster and uses less current. The newer engines use these. I switched starters and was really surprised at the improvement
I have been using the GM 4 pin module for 3-4 years with out any problems... with the feedback carb. And yes I have collected enough stuff to do the DS2 swap... but don't see the point as nothing will improve. My only motivation to change ANYTHING is better gas mileage.
Good luck, Jim
starter info
https://www.ford-trucks.com/forums/8...-opinions.html
Any MPG estimate before and after your upgrade.?
Did you have any of the symptoms before upgrade..black smoke, ping , lack of power etc ? I have none of these thats whats confuses me . But have a feeling my MPG will suck and if so will do the conversion.
Thanks
So the point is I never did get a clean base line for before and after testing.
I did notice more power with the DS2 Dist swap.
My best gas mileage is 17 mpg at 60-65 mph, that's with a C6 auto, no overdrive.
You should really check your freeway gas mileage on a long trip before you spend money to try and improve it, it might be good enough as is.
Jim
But after reading these post I know im not done yet . Will get gas milage estimates this summer and even if there decent how can I not try to improve . At under $150 can do ignition swap [ And can purchase parts in my own country ] wow .lol
Even if I gained only 1 or 2 mpg it would pay for cost of swap in little time with the price of fuel . Not to mention knowing the motor would be running at its full potential . Well almost .. the carb thing is another story.
Well that would be to good to be true..will see. If not your option has given me new hope .
Thanks to all for a very informative thread..
Partsremoved2_zpsdc88c32b.jpg Photo by wannavan | Photobucket
I have a 12 volt tester and have power to pos and neg from coil on chevy ignition moduale [B and C posts] But no power to other end of moduale to distributor [post G and W] Have ignition on of course. Even crank engine and no power to other side of moduale. Dont know anything about testing electrical componants so take it easy on me. Should I not read power on other side of moduale ? Have bought 2 moduales and possibly both faulty ? Or I fried them during install ? Or Im using wrong tester and moduale is fine ? Dont know.
Thanks
Thanks
The Dist signal voltage is to small to see with a test light.
Thanks
Dist and module and coil case are all grounded.
12v full current to B+ on module (no resistor or resistor wire for HEI)
Module is grounded to heatsink with the 2 bolts (use thermal compound too)
To test the dist p/u (purple and orange wires, ground connected), set a digital volt meter to AC voltage and spin distributor, should get over 2 vac to fire module.
That's the only voltage you will see for W and G wires.
For retarded starting:
Don't worry about it unless it becomes a problem.
GM had a 5 pin module that you can wire a manual switch to in the cab to retard it ~10° for hard starting.
Will get back to you tiap when I get a volt meter.
Will post parts used and pictures tonight.
Thanks All
