computer question.
Old Feb 23, 2013 | 08:24 AM
tjc transport's Avatar
tjc transport
i ain't rite
there is only one BJf computer listed on www.car-part.com , and they did not put a price on it.
1995
Engine Computer
Ford Van 350 F5TF-BJF stock #G29594 G and T-1-800 Used Parts USA-MI(Chesterfield) 586-749-7799/800-873-3727
Old Feb 23, 2013 | 10:54 AM
77mud's Avatar
77mud
That fuse was blown and wrapped with foil, it has been changed, the WTS Light was working fine. truck still wont start, he couldn't get his scanner to communicate with the computer, and like i said the computer has been wet a good bit, it is rusted up and corroded
77mud's Avatar
77mud
I saw that one Tom, found one or 2 on Ebay but they want like 285-300 bucks for them used.
Old Feb 23, 2013 | 12:26 PM
Hussler's Avatar
Hussler
Idiots that wrap foil on a fuse ... . In any case be sure to repair or unplug the fuel filter heater. Actually fuse #22 controls the PCM relay coil, another fuse powers the PCM through through that relay contacts.
I don't want to beat a dead horse here but you indicated the WTS light was working .. when did it stop working, when the foil was removed and the fuse was replaced? If the fuel heater is shorted fuse #22 will keep blowing, PCM will have no power and a scanner will not connect. It's sometimes hard to see if fuse #22 is blown visually but an ohm meter should tell the story ..
Old Feb 23, 2013 | 02:09 PM
77mud's Avatar
77mud
The WTS light never quit working, all fuses were replaced and checked the codes again still nothing, He traced everything for a short and located nothing anywhere and the fuses are all still fine, truck still wont crank and the computer still wont come on enough to communicate
Old Feb 23, 2013 | 03:00 PM
madpogue's Avatar
madpogue
Did you TEST the fuses in the interior fuse box as well?
Old Feb 23, 2013 | 03:50 PM
Hussler's Avatar
Hussler
Good luck, hope new pcm and your mechanic fixes the problem ...
Old Feb 23, 2013 | 10:25 PM
77mud's Avatar
77mud
all fuses were checked especially after finding 3 of them with foil on them.
maybe it will, in most case's I maybe questioning the guy working on it, but the guy working on it is a family friend that i have known since i was old enough to remember him. my dad and his oldest brother grew up together so it is one of those instance's were i actually trust someone with my truck.
Old Feb 24, 2013 | 07:27 AM
Usaman's Avatar
Usaman
I'm sure someone else will chime in on this but I think the PCM needs to match the tranny type.
Old Feb 24, 2013 | 08:05 AM
77mud's Avatar
77mud
Thats kinda what i was trying to ask. and the answer i found searching was pretty much any OBS Powerstroke that has a Automatic trans. I know that obviously one with a stranded trans wont work in a automatic transmission type.
Bmac71
Jan 18, 2018 08:29 AM
jacsent
Oct 3, 2012 10:25 AM
MarkZ
Feb 3, 2007 03:38 PM
pud
Nov 8, 2006 11:04 AM
JL_Aero
Aerostar
Aug 30, 2003 08:06 PM
