removing computer (PCM)
Old Feb 3, 2007 | 02:50 PM
MarkZ's Avatar
MarkZ
Ok, I spent a fair amount of time, and a lot of pages searching on a dial-up system and came up with zilch. I've seen it a year or so ago. I took the two bolts out of the bracket and the box seems to slide out about a 1/2" then stops.
Someone had instructions for removing the computer. I need to find out if I have a chip or not. Another question, can you pass emissions with a tune or do you need to go back to the stock tune (which I don't seem to have)?
Thanks for all your help!
Old Feb 3, 2007 | 03:07 PM
DavidT.'s Avatar
DavidT.
There's another bolt under the hood below the brake master cylinder that holds the wiring harness connector to the PCM. Without that bolt out and the wiring harness connector disconnected, the computer will not slide out.
Old Feb 3, 2007 | 03:11 PM
guzzle92's Avatar
guzzle92
Did you disconnect the PCM plug in the engine compartment from the PCM?
Old Feb 3, 2007 | 03:17 PM
MarkZ's Avatar
MarkZ
Thanks for all the help! As always you guys are awesome. If only the parts guy could be so fast!
Old Feb 3, 2007 | 03:21 PM
ron's power stroke's Avatar
ron's power stroke
this is for installing the DP tuner..but it tells you how to remove the pcm...
http://www.itpdiesel.com/other/DP-Tu...stallation.pdf
Old Feb 3, 2007 | 03:35 PM
MarkZ's Avatar
MarkZ
On the same subject, do I have to disconnect the batteries first...I hope not because if I do I just blew it.
Old Feb 3, 2007 | 03:38 PM
ron's power stroke
read the instruction i poted above..it will tell you just how to do it..no you do not need to un hook them..just take the key out..how ever when i did my chip i un hooked them..
rdinmv
Feb 13, 2014 06:28 AM
DNTTRY
Modular V10 (6.8l)
Jan 30, 2013 01:16 PM
JEbrake
Jun 22, 2012 02:36 PM
frankat1
Mar 12, 2009 09:25 PM
rbloodhound
Computer Chips & Tuners
May 14, 2008 03:50 PM
