injector replacement?? p0263 p0278
My truck has been misfiring if you let it idle longer than 2-3 min. From what im reading I have a couple bad injectors and possibly an EGR cooler leaking. Has anyone replaced injectors without pulling the cab or moror? Any other ideas would be appreciated. Thanks.
2008 F250 H&S tuner, DPF delete and an intake.
Injector diag on a 6.4L can either be diagnosed during cold engine startup with the weak cylinder compensation strategy disabled, just like it's done on a 6.0L to pinpoint 'low' cylinders, or by monitoring individual fuel trims at idle. As far as changing them out goes, the cab does not need to be removed. If you are brave enough to decide to attempt changing them out yourself, just bear in mind that the torque specs for both flare fittings to the injector as well as the hold-down need to be followed EXACTLY to the tee. Another caution is with regard to the plastic heater hose tubes on each side of the engine. They do break easily, which if you do, you'll be having a very bad day changing those out as well.
I do have a heated garage with lift if I do it myself. Ill just have to have the dealership tell me whats wrong
One other thing...you said you were loosing coolant (minor). You could do a OA and see if you have any coolant in your oil.
While you are in there doing injectors check those hoses next to the motor. The o-rings on the orginal style hoses are just a single o-ring and they will leak.
Updated ones are double o-rings and work well. End of the hoses on the new style are white.
AubieTN
13
01-24-2020 04:15 PM
Olds64
11-06-2018 10:38 AM
