I beam suspension
Old May 31, 2003 | 12:53 PM
Broncobomber's Avatar
Broncobomber
I beam suspension
New to site, investigating older ford trucks with I beam suspension, what I am wondering is what years did Ford make its I beams "equal length" I think it was in the 70's but what exact year range. Thanks
Old Jun 1, 2003 | 12:10 PM
theonlybull's Avatar
theonlybull
I beam suspension
they went to the twin I-bean suspension in the early/mid 60's, and they've always been equal length in the 2wd I-beam suspensions.
Old Jun 1, 2003 | 02:10 PM
Torque1st's Avatar
Torque1st
Posting Legend
I beam suspension
The vans have unequal length I-Beams because of the engine offset, at least in the -85+ body style.
Old Jun 4, 2003 | 03:47 PM
Broncobomber
I beam suspension
RE: they've always been equal length in the 2wd I-beam suspensions
Are you sure on that? from 1980-1996 the 2 wheel drive I beams if taken off the truck and measured, one of them is longer than the other
Vans actually have equal length beams I believe, along with late 70s pickups and camper special
Old Jun 4, 2003 | 05:55 PM
theonlybull
I beam suspension
73-79 all have equal length I-beams, and i know the 65-72 have the same I-beams
as for 80 on, i really don't know
Old Jun 4, 2003 | 11:53 PM
Torque1st's Avatar
Torque1st
Posting Legend
I beam suspension
I pulled a set of TIB's from an 85 E350 last year and they were very definitely NOT the same length by several inches, not just a small difference,
TIB's were introduced in 65. My 64 had a straight axle.
Old Jun 5, 2003 | 05:37 AM
theonlybull
I beam suspension
woo. you mean i guessed the right year eric. lol a friend of mine has a 65 f-100, and a 66 f-250, and we were considering using my old i-beams from my parts truck, so he could have disc brakes....
Old Jun 5, 2003 | 06:02 PM
Torque1st's Avatar
Torque1st
Posting Legend
I beam suspension
Slide up under and measure the distance from the spring center bolt to the pivot bolt on both sides. If it is close you can proabably make it work. Watch out for differences in the steering linkage and box setup tho.
nvrgrwup
Oct 4, 2015 08:23 PM
killer608
Sep 24, 2015 09:13 PM
coopster17
Sep 10, 2015 09:59 PM
toohott7718
General Automotive Discussion
Mar 3, 2015 09:47 PM
