Hood adjusting bumpers
Old Feb 20, 2013 | 07:01 AM
devin28's Avatar
devin28
Hello. I have a quick question regarding the hood adjuting bumpers. I have a 1977 Ford F150. My hood shakes around the front corners when i'm traveling at higher speeds. My grandfather showed me where the hood adjusting bumpers go. Said he must of taken them off. My question is, broncograveyard.com offers two different ones.
Hood adjusting Bumper #16001 and OEM Style Hood adjusting bumper #16001SD.
Which one works best and how many of them will I need? They install on the top correct?
Old Feb 20, 2013 | 08:38 AM
Wbruiser2's Avatar
Wbruiser2
Are you sure these aren't what you need?:
Item 2 Truck Parts and Truck Accessories
I never heard of an adjusting bumper, they just screw in. You might need to adjust your hood latch after you replace them.
Old Feb 20, 2013 | 09:18 AM
devin28's Avatar
devin28
Yeah I'm sure those arnt it. Broncograveyard offers some bolts that have a rubber peice on one end to adjust it.
Old Feb 20, 2013 | 11:49 AM
HIO Silver's Avatar
HIO Silver
The hood bumpers are not adjustable. They just act as pads.
If your hood is bobbing up and down, the hood needs to be adjusted so there is no gap between the bumper and the fenders. Be patient. Hood adjustments will drive ya nuts because the front end sheetmetal and hinges have very, very loose tolerances unlike today's cars/trucks.
Old Feb 20, 2013 | 11:55 AM
devin28's Avatar
devin28
hood bumpers
Well i do not have any hood bumpers. Im pretty sure thats why my kinda shakes at high speed. It opens and closes fine. I ordered the ones from bronco graveyard. The #16001SD with the big rubber pad on them. I ordered two. Hopefully this help.
Old Feb 20, 2013 | 12:09 PM
Wbruiser2's Avatar
Wbruiser2
I'm pretty sure your truck didn't come with those... Just the rubber in the link that I sent you before. What you ordered is for a bronco..
Old Feb 20, 2013 | 12:46 PM
JRB65's Avatar
JRB65
devin28,
I was just getting ready to ask the same question you did. My Hood is rocking back and forth and there are what look like a place for the bumpers you discribed on my truck. Thanks for the info and let me know if they fix your problem. If they do I will be ordering some as well...
JRB65
Old Feb 20, 2013 | 01:22 PM
montana_highboy's Avatar
montana_highboy
Our trucks don't have adjustable hood bumpers, they have (4) fixed bumpers instead, what you bought is for the early Broncos.
If your hood is shaking at highway speeds your hood latch needs adjusted and/or your bumpers are missing.
Old Feb 20, 2013 | 06:43 PM
JRB65's Avatar
JRB65
montana_highboy, thanks for the help..
Adjusted the hood latch and the high speed wabbles are gone. I have to tell you though I didnt have to move it much to get it to adjust properly. The hood line is decieving as it looks strait down the side of the hood even when it wasnt adjusted right... It may be a good Idea to replace the Hood Bumpers just as cheap insurance incase the old ones are worn out...
JRB65
Old Feb 20, 2013 | 07:18 PM
devin28's Avatar
devin28
bumpers
I have the 4 square rubber bumpers that go on the seam or whatever on the hood. I ordered 4 new ones just to give it a shot. They were cheap enough. The hood opens and shuts just fine. Still pops open when I pull the latch. The shaking hood problem seems it just comes from the front corners. Can this still be a hood latch problem?
Thanks for the input so far.
Old Feb 20, 2013 | 07:30 PM
montana_highboy
Are the four hood bumpers making contact with the fenders with the hood closed?
Old Feb 20, 2013 | 07:50 PM
devin28's Avatar
devin28
That i do not know. Now that I think about it, it doesn't feel like rubber is hitting anything when the hood closes.
Old Feb 20, 2013 | 08:21 PM
HIO Silver's Avatar
HIO Silver
I'll quote myself because apparently you didn't read it the first time.
Old Feb 20, 2013 | 08:24 PM
devin28's Avatar
devin28
very well HIO. Thanks for requoting yourself. I will install new rubber. Adjust accordingly and that shout fix it. Thanks for the help.
Suffolkman
Feb 15, 2019 09:27 PM
bulldogcountry1
Jun 13, 2018 02:35 PM
mjr46
Jun 15, 2016 07:40 PM
51f1truck
Mar 22, 2010 07:09 PM
mstiles19
Feb 11, 2008 10:29 PM
