ZF removal
Old Feb 16, 2013 | 09:52 PM
jgavac's Avatar
jgavac
ZF removal
I'm going to be pulling the ZF s5 out of my 87 idi in the next few days to do some work on it, and I'd appreciate a few pointers if possible. I've only pulled two other transmission since I started working on vehicles, one was a C6 out of my 79 that I pulled in conjunction with the engine, straight out the front, and a T18 sans clutch housing out of a 78 that already had the engine out.
My plan was to detach the driveshaft, hydro lines, and pull the shift lever out, then remove the cross member and support it with a jack, unbolt it from the engine, slide it back, then pull it out from underneath.
Does that sound like a solid plan? I don't have any experience really in this department of transmission removal.
I don't have a trans jack, so I suppose I could rent one, or go from up top with a engine hoist like Alvin in AZ did? Or are there any other ways to go about it?
Lastly, any quirks I should be aware of?
Much Appreciated
Jameson
Old Feb 16, 2013 | 10:16 PM
mdh1701's Avatar
mdh1701
Solid plan, but a decent floor jack with a tranny adaptor will work wonders. Usually you can get these at NAPA, AutoZone, etc. Otherwise yes sounds good!
Actually, since you have a diesel, you can just unbolt the slave cylinder from the bellhousing so you don't have to bleed it out afterwards. Pull the clutch fork then proceed as planned. Good luck!
PS: Make sure not to push the clutch pedal while the tranny is out. I can tell you from experience it won't end well...
Old Feb 17, 2013 | 09:18 AM
tjc transport's Avatar
tjc transport
i ain't rite
you can buy a trans jack from harbor freight for under $80. it is well worth the price.
Transmission Jack - 450 Lb. Capacity
look in the sales fliers, and i bet you cam pick this one up for under $50
i have had the same one for 8 years, and use it all the time.
Old Feb 17, 2013 | 11:44 AM
Alvin in AZ's Avatar
Alvin in AZ
Wow that sounds cheap enough! :)
Maybe even pick up a used one from Craig's list?
Do the autoparts stores rent those out? :)
For me, it depends on whether you want to take out the seat and carpet.
I -want- to, it's my chance to do other stuff while I'm at it, see? :) YMMV
Either way it's a straight forward process, things like twisted off bolts and
parts that don't fit and things like that, aren't part of transmission work in
my experience.
Just reading where it sounds like about half the guys that change out a
water pump on a 351w twist a bolt off or two, one guy twisted off three.
(3 out of 3 ...I hadn't twisted off any;)
Alvin in AZ
NewRed
Feb 18, 2009 09:34 PM
runinbear
Jan 16, 2008 09:20 PM
FrontRangeF150
Mar 7, 2007 05:36 PM
Charger73400
1983 - 2012 Ranger & B-Series
May 8, 2005 08:26 PM
84FB351
Jun 2, 2004 10:55 PM
